Need help drag shock rear a body
#1405700
03/20/13 11:31 PM
03/20/13 11:31 PM
Posts: 1,030 ohio
67mprfan
ohio
Hello everyone do they make a shorter rear drag shock for a demon, my problem is i put on a comp eng shock part #247-2730 and it's to long when i attach it,....it sit bolt hole to hole collapsed looking for any other make that are shorter.......btw rear end is set up leaf link.........Thanks
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Need help drag shock rear a body
[Re: 67mprfan]
#1405701
03/21/13 05:57 AM
03/21/13 05:57 AM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
I found a shorter Rancho for mine........
[Re: 10.90 Racer]
#1405702
03/21/13 09:54 AM
03/21/13 09:54 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have a shorter afco on mine.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 10.90 Racer]
#1405703
03/21/13 05:34 PM
03/21/13 05:34 PM
Posts: 1,030 ohio
67mprfan
ohio
do you have a part #
[Re: a493demon]
#1405706
03/21/13 07:12 PM
03/21/13 07:12 PM
Posts: 3,210 robin hood country
deaks
robin hood country
calvert does two different lengths for mopars, one for SS springs and one for caltracs. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 67mprfan]
#1405708
03/22/13 12:12 AM
03/22/13 12:12 AM
10.90 Racer
super street
super street
Ont. Canada
I will look tomorrow.....
[Re: 10.90 Racer]
#1405709
03/22/13 02:51 AM
03/22/13 02:51 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
3890 is LONG, like 24 inches extended I think with 9 inches of travel. I've been doing alot of shock research recently and my car (@15.5 inch ride height between shock mounts) needs a 3860 from Afco (6 inches travel, closer to 20" fully extended. They also make a 3870 which is in between the two.
You need to take measurements of your suspension at ride height, with weight in the driver seat, as well as full droop/extension, and go from there.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: 1967dartgt]
#1405712
03/23/13 10:02 AM
03/23/13 10:02 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Afco #3860 on my '68 Valiant w/ladder bars and coilovers. Double adjustable, 125# springs. Car is a little over 3300# with driver.
If you like drag racing, support your local track.
[Re: CHAPPER]
#1405713
03/24/13 08:38 PM
03/24/13 08:38 PM
Posts: 1,030 ohio
67mprfan
ohio
I've heard don't know how true but you can run a shock off of a 3/4 pick up truck with some sucess( staying on a budget)
