Re: New Toy
[Re: OzHemi]
#1405505
01/16/14 04:39 PM
01/16/14 04:39 PM
Posts: 2,915 A shed in England
Tig
A shed in England
whats the steeringbox and idler arm bolted to ?
Looks like the same setup the Aussie cars used, and they bolt to the frame rail. (with some through-the-rail crush tubes)
Some of them would crack the rails on the bottom side where it mounts, so always good to check them out there.
Pretty much the same and it has had repairs in that area. Rack and pinion swap would be nice
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: New Toy
[Re: Tig]
#1405506
01/16/14 05:52 PM
01/16/14 05:52 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I didn't drag race my car...but the rack was a great upgrade, wish I had done it a long time before. (The setup has been done in Oz for a while now.) Paul Norris at the link I mentioned above is who did my K frame. You need to modify the steering shaft, but it's nothing all that hard. Oh, and with a V8 you need to notch the sump a little to clear the rack, or shim the engine mounts a bit. With the Hemi-6 it clears as is..
Re: New Toy
[Re: OzHemi]
#1405507
01/16/14 07:25 PM
01/16/14 07:25 PM
Tig
A shed in England
Thanks for the link, very helpful. This was supposed to be a quick, cheap and easy daily driver project. Things can escalate, you know how it is
Re: New Toy
[Re: OzHemi]
#1405510
01/16/14 09:05 PM
01/16/14 09:05 PM
Tig
A shed in England
By the way...another difference from memory, the lower ball joints on the Oz cars are a slightly different length to the USA ones, if you ever go to change them out..not sure on what your's may have on it?
Thanks for the tip Most likely stay with manual set up
Re: New Toy
[Re: OzHemi]
#1405513
01/17/14 03:51 PM
01/17/14 03:51 PM
Tig
A shed in England
Very similar oil filter setup but at the front, mounted on the water pump. It's gone the journey as there was crusty old oil and dirt over the chassis rail and the rear of the engine, the seals had gone and I couldn't get them anywhere. Now have an aftermarket remote set up, much better No pics unfortunately. Edit: I noticed the oil cover has twin lines on your buddies motor, UK cars had a single outlet with stacked blocks to which the steel lines where attached. It was crap Found a pic, though not of ours.
