Re: External Oiling System Question
[Re: Big Wedge]
#1403034
03/17/13 02:10 PM
03/17/13 02:10 PM
Posts: 85 Colorado Springs, Colorado
cool70cuda
Garth & Rick, that is some great documentation! I thought I was the only one who took a bunch of step by step photos of everything seeing the pics make it much easier to understand Garth, the modified fitting coming out of the pump cover would be my biggest problem...That is some awesome skill cutting and welding up that fitting I don't have that skill and not sure any of my friends do either. Rick, the tubing you used, is it welded or soldered? Also, question for all: Are you using the "O" ring at the connection/fitting at the pan or a gasket of some sort...or both?
[Re: cool70cuda]
#1403039
03/17/13 07:43 PM
03/17/13 07:43 PM
Posts: 314 Manitoba, Canada
Big Wedge
Manitoba, Canada
Bill, the fitting was not too bad to make. I just cut out a V from a 90 and filed it by hand until it lined up with the opening in the cross member. A friend of mine did the TIG welding. Remember, this is under suction, not pressure.
I remember having to fiddle with the pickup. I forget how I did this. Now you understand why I have some many pictures. LOL. My best recollection was I discarded the o-ring. I used an aluminum washer on the outside of the pan. I had a friend thread it to better align it on the fitting but that is not necessary. Then I used silicone on either side of the sump wall to seal.
Garth
[Re: MRMOPAR]
#1403040
03/17/13 07:52 PM
03/17/13 07:52 PM
Big Wedge
Manitoba, Canada
BigWedge - looks like that block was ventilated in one picture.
Yup. That is now my mock up block for myself and Mopar friends.
Garth
[Re: cool70cuda]
#1403041
03/17/13 10:08 PM
03/17/13 10:08 PM
Posts: 916 MB,CAN
PC-CHARGER
MB,CAN
The tubing is welded. I don't think soldering would hold in this application. It was fabricated from two 90 degree Aeroquip adapters. As for the fitting in the pan, I used a washer kit from Doty manufacturing that is made specifically for this application. It is a large aluminum washer that is relieved for an "O" ring on the inner circumference. http://dotymi.comGarth's method or mine each require some welding although it is minor and any welding shop would likely do it for a minimal charge. I would think that a longer piece of braided steel line could be looped under the oil filter in place of the steel line I used and would eliminate any welding but the line would have to be supported so it doesn't rub somewhere.
