Driveshaft Length Help (and Slip Yoke)UPDATE
#1402889
03/15/13 06:05 PM
03/15/13 06:05 PM
Posts: 2,709 NJ central
Scamp408
NJ central
Just got my trans back in and while putting my DS back in I only have a 1/2" of room until it bottoms out. This is with the car on jackstands but on axle and control arms. Is This enough play?
Re: Driveshaft Length Help With Caltracs
[Re: Scamp408]
#1402890
03/15/13 06:24 PM
03/15/13 06:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've always run 3/4" as the spec.... 1/2" might be on the close side... would hate to see you bottom out and bust up stuff ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Scamp408]
#1402892
03/15/13 06:36 PM
03/15/13 06:36 PM
Triple Threat
Renton Washington
That's pretty tight, if you let the rear end hang it will probably get even tighter.
[Re: Scamp408]
#1402894
03/15/13 06:42 PM
03/15/13 06:42 PM
Scamp408
NJ central
I ran it like this for years but thought 1/2 was too close.
On SS springs and 1 year on monos.
[Re: Scamp408]
#1402896
03/15/13 09:46 PM
03/15/13 09:46 PM
MR_P_BODY
So Mr P I should look for 3/4? I will get it on the ground and ck it again and also ck the pinion angle to make sure nuttin moved.
The Munroe trans book says 3/4"... so thats what I have been using for years ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1402897
03/16/13 08:17 AM
03/16/13 08:17 AM
Posts: 2,937 A shed in England
Tig
A shed in England
You could try shimming out the front spring hangers 1/4 inch. If you have the room for the tyre ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1402898
03/16/13 09:36 AM
03/16/13 09:36 AM
MR_P_BODY
This is what I would do... in most cases it centers the tire better in the wheel well ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1402899
03/16/13 11:22 AM
03/16/13 11:22 AM
Scamp408
NJ central
Already have the axle 1in back but thanks. I think the yoke is the problem. I have a output shaft for a 727 handy and it only slides in so far,it doesnt bottom out. I also have an old mopar yoke and it bottoms out on both extra shaft and trans.I looked inside yoke but cant see any damage but it does fit tighter than the mopar one.
[Re: Scamp408]
#1402902
03/17/13 01:41 PM
03/17/13 01:41 PM
Scamp408
NJ central
The splines arent twisted but down inside some may look weird I may have to rethink this all over because of this I may be to short.
