Where can I find distributor shaft bushings? #1402581
03/15/13 01:32 AM
03/15/13 01:32 AM
Beans Cove Pa
Bumbalawski Offline OP
Beans Cove Pa
I am looking for two distributor shaft bushings for a 1970 OEM dual point distributor. Does anyone know of a supplier for these? I have searched the web and found none.
Pm me or e-mail dodgeboy69@atlanticbb.net
Thanks,
Don
Re: Where can I find distributor shaft bushings? [Re: Bumbalawski] #1402582
03/15/13 11:52 AM
03/15/13 11:52 AM
iirc I found some for sale way back (for a single point) from "Arizona Parts". google it & go from there
Re: Where can I find distributor shaft bushings? [Re: Bumbalawski] #1402583
03/15/13 01:19 PM
03/15/13 01:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thanks,
Don
It's a standard bushing you can get at Lowe's.just shorten it 1/8" and cut the slot for the oiler if it's a Prestolite dual point.
O.E.M. on left
Re: Where can I find distributor shaft bushings? [Re: 62maxwgn] #1402584
03/15/13 05:13 PM
03/15/13 05:13 PM
if it's a standard bushing you can get at Lowe's.
Re: Where can I find distributor shaft bushings? [Re: 62maxwgn] #1402585
03/15/13 05:19 PM
03/15/13 05:19 PM
MA
steve70 Offline
steve70  Offline
MA
Does anyone have the physical dimension of the correct bushing?
1970 Challenger T/A 4 speed
Re: Where can I find distributor shaft bushings? [Re: steve70] #1402586
03/15/13 08:16 PM
03/15/13 08:16 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
i have some somewhere....will try and dig them up and give dimensions
Re: Where can I find distributor shaft bushings? [Re: Joesixpack] #1402587
03/15/13 08:32 PM
03/15/13 08:32 PM
Shoulda known, William would have a half a dozen sets of NOS ones in his dresser drawer
Re: Where can I find distributor shaft bushings? [Re: RapidRobert] #1402588
03/15/13 09:32 PM
03/15/13 09:32 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
McMaster-Carr probably has a bushing that is very close. Especially if lowes has something that will work.
Re: Where can I find distributor shaft bushings? [Re: RobX4406] #1402589
03/16/13 01:07 PM
03/16/13 01:07 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The shaft is 1/2" , in the hardware section at a REAL hardware store , like an ACE or True Value, where they have the bolts and other clips and such they have a bin with bronze shaft bushings, there is only 1 or 2 that are 1/2" ID . the length is around and 1".
Re: Where can I find distributor shaft bushings? [Re: JohnRR] #1402590
03/17/13 01:35 PM
03/17/13 01:35 PM
Beans Cove Pa
Beans Cove Pa
I went up to Lowes today. The bushings were there like Bill had said. They are 1/2"X5/8"X1 1/8"(.500"X.625"X1.125"). They were $2.69 each. Lowes item number is 215749 and model number is 882746.
Re: Where can I find distributor shaft bushings? [Re: Bumbalawski] #1402591
03/17/13 03:58 PM
03/17/13 03:58 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
u can get em from the dealer, not expensive at all
Re: Where can I find distributor shaft bushings? [Re: Bumbalawski] #1402592
03/17/13 04:32 PM
03/17/13 04:32 PM
What reamer are you going to use? (I need to do the same thing)
Re: Where can I find distributor shaft bushings? [Re: RapidRobert] #1402593
03/17/13 07:21 PM
03/17/13 07:21 PM
Beans Cove Pa
Beans Cove Pa
I did not need to ream them. I cut the oil slot in the upper bushing, pressed them in the housing and the shaft fit very nicely. I guess I got lucky.
Re: Where can I find distributor shaft bushings? [Re: Bumbalawski] #1402594
03/17/13 07:23 PM
03/17/13 07:23 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
we all know the seller... but being the original and full kit:
http://www.ebay.com/itm/1960s-1970s-Dist...de9&vxp=mtr
Re: Where can I find distributor shaft bushings? [Re: NachoRT74] #1402595
03/17/13 08:55 PM
03/17/13 08:55 PM
JohnRR Offline
JohnRR  Offline
2 bushings at Lowes for 2.69 each is better than sending that [censored] a dime ...
Re: Where can I find distributor shaft bushings? [Re: NachoRT74] #1402596
03/17/13 09:47 PM
03/17/13 09:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
But,that is for the Chrysler aluminum distributor,not the Prestolite,wrong collar for the shaft and you still have to cut the upper bearing notch for the oiler !
Re: Where can I find distributor shaft bushings? [Re: 62maxwgn] #1402597
03/18/13 01:41 PM
03/18/13 01:41 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
ok here is a photo of original bushings
Re: Where can I find distributor shaft bushings? [Re: Joesixpack] #1402598
03/18/13 01:42 PM
03/18/13 01:42 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
pic#2
Re: Where can I find distributor shaft bushings? [Re: Joesixpack] #1402599
03/18/13 01:45 PM
03/18/13 01:45 PM
JohnRR Offline
JohnRR  Offline
looks like you have a few there Bill , are those Prestolite or Chrysler ?
Re: Where can I find distributor shaft bushings? [Re: Joesixpack] #1402600
03/18/13 01:45 PM
03/18/13 01:45 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
.500 id
.627 od
1.000
length
