Re: Where can I find distributor shaft bushings? [Re: Joesixpack] #1402601
03/18/13 01:46 PM
03/18/13 01:46 PM
dogdays Offline
dogdays  Offline
Are the originals Oilite? If so, a plain bronze bushing might not be what you need.
R.
Re: Where can I find distributor shaft bushings? [Re: dogdays] #1402602
03/18/13 01:47 PM
03/18/13 01:47 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
R.
Good point .
Re: Where can I find distributor shaft bushings? [Re: JohnRR] #1402603
03/18/13 01:52 PM
03/18/13 01:52 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Filko&Niehoff
Re: Where can I find distributor shaft bushings? [Re: Joesixpack] #1402604
03/18/13 01:53 PM
03/18/13 01:53 PM
JohnRR Offline
JohnRR  Offline
Filko&Niehoff
Do those fit Prestolite or Chrysler distributors ?
Re: Where can I find distributor shaft bushings? [Re: JohnRR] #1402605
03/18/13 05:40 PM
03/18/13 05:40 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Here's the contents of the Chrysler dual point distributor "bearing & parts package"
Re: Where can I find distributor shaft bushings? [Re: twodoorpost] #1402606
03/18/13 10:26 PM
03/18/13 10:26 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
All good info here.
Re: Where can I find distributor shaft bushings? [Re: JohnRR] #1402607
06/15/14 09:32 PM
06/15/14 09:32 PM
GMP440 Offline
GMP440  Offline
The bushings at Loew's state on the package that they are oil impregnated. That should be ok to use for the distributor.
Re: Where can I find distributor shaft bushings? [Re: GMP440] #1402608
06/15/14 10:45 PM
06/15/14 10:45 PM
My SB manual states to drive in the upper one till it is 1.163" down from a straight edge across the dist round perimeter and the lower bushing flush with the bottom housing (single point alum dist)
