Re: Anyone using the Airwolf heads yet?
[Re: Streetwize]
#1402413
03/14/13 07:36 PM
03/14/13 07:36 PM
Posts: 41 anaheim Ca
Bryce Mulvey
anaheim Ca
We have sent a lot of sets out the door. I now we will be hearing some results once the snow melts and I can't wait. We are still trying to keep up with the demand and we getting a handle on it slow but surely.
Bryce Mulvey
Dr J's Performance
The Home of AIRWOLF Cylinder Heads
[Re: mshred]
#1402416
03/14/13 10:06 PM
03/14/13 10:06 PM
Posts: 9,870 Weddington, N.C.
Streetwize
Weddington, N.C.
Mopar65, Can't say since I bought it off another Moparts Member but I have talked to Lenny about doing some other work for me. Everything I've heard about UCC is top notch. The Airwolfs and the Vert will be getting a work out this season though!!
[Re: 72 Dodge demon]
#1402418
03/18/13 09:53 AM
03/18/13 09:53 AM
Streetwize
Weddington, N.C.
I'm hoping for another 50-ish HP over my ported Shady Dell stage 2's; apples to apples, they should raise the powerband another 400-500 rpm, the SDII's were all done by around 6100 on my 414, with 4.56's I was out of RPM and gear by 1100' and that was on a part throttle launch check-out pass. To be fair the 4.56 set-up was intended for 1/8th mile. The SDSS's are great heads for the $$$ though, HUGE improvement over bowl ported/Vj'ed Eddies.
I swapped to the Airwolfs and also dropped the gear down to 4.10, also re-did the 904 to the low gear set to keep my 1st gear pretty close to identical.
Should be fun either way, net-net the Airwolfs were only a net $500-ish upgrade after selling the SDSS's.
[Re: Streetwize]
#1402419
03/30/13 05:41 PM
03/30/13 05:41 PM
Posts: 66 Kentucky
72 Dodge demon
Kentucky
Just got home swapped the stage two Hughes engine Eldelbrocks for the airwolfs. I ran a comps cam solid lift and switched to a bullet roller. Everything off the edelbrocks bolted to the airwolfs. The last pass last year the car ran a 6.03. The first pass today was a 5.96 spinning and letting off the big end. Then a 5.86 and 5.87 cutting out on the top end at 116.
#1402420
03/30/13 07:12 PM
03/30/13 07:12 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I will def be looking into a set when I get around to building my long armed LA...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: 72Swinger]
#1402425
03/31/13 09:10 AM
03/31/13 09:10 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
what is a airwolf head
Fellatio in a Helicopter...
#1402426
03/31/13 10:22 AM
03/31/13 10:22 AM
Posts: 3,414 Toronto
mshred
Toronto
Just got home swapped the stage two Hughes engine Eldelbrocks for the airwolfs. I ran a comps cam solid roller and switched to a bullet roller. Everything off the edelbrocks bolted to the airwolfs. The last pass last year the car ran a 6.03. The first pass today was a 5.96 spinning and letting off the big end. Then a 5.86 and 5.87 cutting out on the top end at 116.
Thats what im talking about!
So definitely an improvement, which is always nice to see when making a switch...what was the issue with cutting out? Fuel?
[Re: 72Swinger]
#1402427
03/31/13 10:24 AM
03/31/13 10:24 AM
mshred
Toronto
LMAO!!! Funniest post I have ever seen on moparts since I have joined here LOL
#1402428
03/31/13 10:36 AM
03/31/13 10:36 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
may be the cam change made the differences what was the specs before and now
