Help with Moroso 4 Vane enhanced vacuum pump #1401089
03/11/13 11:16 PM
03/11/13 11:16 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
Just put the racepak on and it shows 21" of vacuum above 5000rpm I have the regulator set for 11" and anything passed 14 my oil pressure starts to go down. Have you had to modify the regulator beyond their instructions to get the vacuum down?
This is what I have.
http://www.summitracing.com/parts/mor-22633
Re: Help with Moroso 4 Vane enhanced vacuum pump [Re: JD Dart] #1401090
03/11/13 11:58 PM
03/11/13 11:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Wish mine sealed that well Actually I use the Star regulator for the MOroso pump. Works much better as does thier baffle.
Re: Help with Moroso 4 Vane enhanced vacuum pump [Re: Al_Alguire] #1401091
03/12/13 12:13 AM
03/12/13 12:13 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Al you have a four vane also?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Help with Moroso 4 Vane enhanced vacuum pump [Re: JD Dart] #1401092
03/12/13 11:31 AM
03/12/13 11:31 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I ran the enhanced 4 vane 22842 on my 430 - with the 22633 regulator.
I had removed all the shims when starting off and added shims to get to 12-14" on my wet sump setup.
IIRC we used 2 shims to get there.
Re: Help with Moroso 4 Vane enhanced vacuum pump [Re: DJVCuda] #1401093
03/12/13 04:38 PM
03/12/13 04:38 PM
HOUSTON,TEXAS
FIREGUY12 Offline
FIREGUY12  Offline
HOUSTON,TEXAS
Beleive it or not sometimes it takes 2 pop off valves. My buddy had to use 2 on his engine to get the vacuum set correctly. 21 inches is a lot of vacuum. Me personally I would not run over 10 inches of vacuum.
Re: Help with Moroso 4 Vane enhanced vacuum pump [Re: FIREGUY12] #1401094
03/12/13 04:48 PM
03/12/13 04:48 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
I'am going to try the one Al is using looks like it will bleed off more air I have 1 shim in it now. I want to get it down between 11-12 If that one doesn't work then I'll have two thanks.
