HEADERS on a 440 - Pros, Cons??
#1400803
03/11/13 11:05 AM
03/11/13 11:05 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
What's your opinion on putting headers on a 440? ![](/ubbthreads/images/graemlins/shruggy.gif) I've got a '75 T-440 in my Challenger that's been bored .030 with a stock cam and has HP manifolds from a '74 B-Body. I've been told these engines need backpressure that can only be had via stock manifolds. I'm not a purist and am getting tired of chasing leaks that are more than likely casued by these old boat anchors... Thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
Re: HEADERS on a 440 - Pros, Cons??
[Re: Plum440]
#1400805
03/11/13 11:28 AM
03/11/13 11:28 AM
Posts: 75,128 A Banana Republic near you.
JohnRR
Huh ??? who said that ?
You want headers go for it , but you're foolish to think you won't be chasing leaks with headers. Your stock manifolds are probably warped , take one off and set the flange that bolts to the head on a good flat surface , you'll more than likely see the center 2 ports are not touching the surface.
[Re: Plum440]
#1400806
03/11/13 11:38 AM
03/11/13 11:38 AM
RapidRobert
What double R said, you want zero backpressure. I'd have your machine shop mill the manifold faces & reinstall them & wouldn't hurt to use gaskets and or a thin smear of gasket cement. OE there were no gaskets used & combined with warpage over time causes the leaks you are experiencing. It'd be the simpleist/cheapest/fastest way to solve your problem.
[Re: Mr.Yuck]
#1400809
03/11/13 12:52 PM
03/11/13 12:52 PM
Posts: 511 AZ.
696pack
AZ.
I laugh at this "back pressure" myth. Headers will add power throughout the power band. Key is to get a good gasket. Don't use the cheap paper one they give you in the kit. Use a Fel-Pro or other decent set. Also cut the flanges, and DO NOT crank the heck out of them and you'll be fine.
Remflex are the best hands down.
[Re: 696pack]
#1400810
03/11/13 01:22 PM
03/11/13 01:22 PM
Posts: 5,949 British Columbia
chrisf
British Columbia
i have used the remflex and they are ok but when i took my headers off after a month i tore the gasket in half. (stuck to the head) i will go back to the percy's seal-4-good, they lasted 7 years and never leaked at all.
[Re: chrisf]
#1400811
03/11/13 02:02 PM
03/11/13 02:02 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Headers just like an internal part subscribe to the old theory... "You get what you pay for". Put on a good set, check the mating flanges for flatness and use good gaskets. I like my Dougs #452. They should fit your application too.
...FAFO...
[Re: RapidRobert]
#1400812
03/11/13 02:11 PM
03/11/13 02:11 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Another yea...
I've had good luck with Ultra-Seal's...
(With no sealer)...
Hooker's were the only one's that gave me 'proper' clearance...
[Re: skicker]
#1400813
03/11/13 02:13 PM
03/11/13 02:13 PM
DaytonaTurbo
Manitoba, Canada
The only real downsides to headers are: Getting them to seal properly. A good gasket makes all the difference. Watch your plug wire routing or you will burn wires or melt plug boots. Tube routing often needs some ![](/ubbthreads/images/graemlins/hammer.gif) for clearance, especially on the cheaper header brands.
[Re: DaytonaTurbo]
#1400814
03/11/13 02:41 PM
03/11/13 02:41 PM
Plum440
Slidell, LA
I'm getting that they are a real pain in the butt. I think I'm going to go the route of keeping the manifolds but having them milled. Afterall, my main concerns are the tiny leaks. The header payoff doesn't seem logical in a car built for "cruising" with an occasional tire peel ![](/ubbthreads/images/graemlins/biggrin.gif) . Thanks! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DaytonaTurbo]
#1400818
03/11/13 08:16 PM
03/11/13 08:16 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Tube routing often needs some for clearance, especially on the cheaper header brands.
dont forget changing the starter is a major PITA.
[Re: bonefish]
#1400819
03/11/13 08:28 PM
03/11/13 08:28 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
If you want about 20 to 30 extra hp go with headers. But if you do just buy a good set like TTI's or Dougs. My TTI's have never leaked as they have thick flanges and dont warp. Most good headers today have thick flanges and seal good. But nothing wrong with manifolds if you are not worried about every bit of power from it. Ron
[Re: 383man]
#1400820
03/11/13 08:53 PM
03/11/13 08:53 PM
Plum440
Slidell, LA
All good points. Starting to lean towards headers to maximize the power from the engine. Why the heck not?!? ![](/ubbthreads/images/graemlins/devil.gif) What about starter clearance and heat soak? Do I need a mini starter or will the stock type be ok? What about heat shielding the starter? ![](/ubbthreads/images/graemlins/shruggy.gif) I think the step-by-step install instructions I found that Mr. Yuk posted some time ago might have helped ease my fears! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: DaytonaTurbo]
#1400822
03/11/13 09:27 PM
03/11/13 09:27 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Headers generate more underhood heat, since you now have 8 radiators passing on the exhaust heat to the engine bay... Along with some spark plug wires melting.. just a pain.. In 30+ years I only had one big block manifold leak that I couldnt fix with simply cleaning up the surface with a 12in mill file.. I wound up with a gasket on that one..no more problems. ![](/ubbthreads/images/graemlins/Twocents.gif)
