Re: Ran the 440 small block Dakota - Thoughts?
[Re: Adobedude]
#1399998
03/10/13 07:38 PM
03/10/13 07:38 PM
Posts: 193 MD
ADakotaRTGuy
MD
Truck is the wrong color...
We will agree to disagree, haha.
[Re: ADakotaRTGuy]
#1399999
03/10/13 07:50 PM
03/10/13 07:50 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Nice passes for being able to run on 87 gas. Lol I think if you changed a few thing it would really pick up.( more gear, some nitrous, bigger conv)
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1400000
03/10/13 07:52 PM
03/10/13 07:52 PM
Posts: 193 MD
ADakotaRTGuy
MD
Have the Nitrous system installed, think we had a solenoid fail or would of had some times with that yesterday.
[Re: ADakotaRTGuy]
#1400003
03/10/13 08:59 PM
03/10/13 08:59 PM
1967dartgt
Hilltown Pa
Looks good, want to sell your valve covers? Plate or fogger?
[Re: 1967dartgt]
#1400004
03/10/13 09:01 PM
03/10/13 09:01 PM
Posts: 193 MD
ADakotaRTGuy
MD
Na, I like the valve covers, they are heavy though. Wasn't someone on here selling a set?
I am using a perimeter plate.
[Re: 1967dartgt]
#1400005
03/10/13 09:07 PM
03/10/13 09:07 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Your heads are misleading. Guys hear W9 and start thinking of heads that flow a minimum of 350. Problem arrives when you are porting and having to allow for the pushrod on a 59 degree block.
Those dakotas are heavy no doubt. 11.25 is probably a decent number for that combo.
If I can help you with your nitrous problems let me know. That is what it needs.
Leon
[Re: ADakotaRTGuy]
#1400007
03/10/13 09:16 PM
03/10/13 09:16 PM
Posts: 936 Deland, Florida
biff426
Deland, Florida
Went and ran my 440 Dakota for the first time today. 59 Degree 4.125 bore/stroke, W9 heads worked by Ryan at SDSS. CR is only 9:1, was supposed to be a turbo motor, but was stationed in Italy so went away from that. Took it to Cecil today and went 11.25 at 118. 60 ft was 1.578, and 1.589 on the good runs. Running 26x10x16 slicks.
A video.
http://www.youtube.com/watch?v=1AZEXKCcUDQ
No credit to Chris at PIE?
[Re: biff426]
#1400008
03/10/13 09:18 PM
03/10/13 09:18 PM
Posts: 193 MD
ADakotaRTGuy
MD
A video.
I did on the other site. But yea, Chris at Performance Injection Equipment built it and brought it to the track for me. Good builder to work with.
[Re: biff426]
#1400009
03/10/13 09:39 PM
03/10/13 09:39 PM
1967dartgt
Hilltown Pa
I would ditch the perimeter plate. Spray bars work much better.
[Re: Streetwize]
#1400014
03/11/13 05:17 PM
03/11/13 05:17 PM
Posts: 193 MD
ADakotaRTGuy
MD
Lower compression might want higher RPM to squeeze some cylinder pressure out of it. You have the head flow to support it ![](/ubbthreads/images/graemlins/thumbs.gif)
Looks like a good app for spray if your not gonna spool it or pull the heads for more CR.
Already have the system in there. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 1967dartgt]
#1400015
03/11/13 05:30 PM
03/11/13 05:30 PM
Posts: 3,397 Pa
Hot 340
Pa
My thought exactly. That combo is the definition of mild and heavy. I think it works pretty good for not being ironed out yet. ![](/ubbthreads/images/graemlins/Twocents.gif)
