TRAILER BATTERY #1399727
03/09/13 06:22 PM
03/09/13 06:22 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
what batterys are you useing in your trailers i have been useing a sears deep cycle it is going bad and needs replaced ! whinch lights etc THANKS
Re: TRAILER BATTERY [Re: dragon] #1399728
03/09/13 06:29 PM
03/09/13 06:29 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Two 6 volt golf cart batteries from costco.....
Re: TRAILER BATTERY [Re: dragon] #1399729
03/09/13 07:20 PM
03/09/13 07:20 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I have the same Interstate, 1000 amp battery, in the trailer for the last 14 years!!!!..
I have a Superwinch 4500, 12 volt lighting when the 110v isnt plugged in...
secret is a Battery Tender.....
Re: TRAILER BATTERY [Re: dragon] #1399730
03/09/13 08:31 PM
03/09/13 08:31 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I use two group 34 yellow top Optima's, the same as the one in the car. So if the car battery has a problem I can swap them.
"Just a Bracket car dressed up like a streetcar"
Re: TRAILER BATTERY [Re: dragon] #1399731
03/10/13 01:37 AM
03/10/13 01:37 AM
Costco brand of thier RV marine deep cycle battery, the biggest one 6 YRS+ in my trailer, CTD Ram and street strip cars with the battery in the trunks My enclosed car trailer has a 12V electric tonque jack Superwinch 4500 lb. winch, electric start generator and two 12V lights inside, no troubles as long as I remember to turn the lights off before locking the trailer up for the week
Re: TRAILER BATTERY [Re: Cab_Burge] #1399732
03/10/13 10:05 AM
03/10/13 10:05 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Optima Red top...I pull it out and put it on a charger for the winter though.
Re: TRAILER BATTERY [Re: dragon] #1399733
03/10/13 11:46 AM
03/10/13 11:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
People dont seem to understand there is 2 different
set ups to run... deep cycle and the standard batteries....
they both have their place... if you run the battery
down on a regular basis you want/need a deep cycle..
if its on a charger/alt all the time you want/need
a standard automotive style battery.. if you tow
veh have a charging circuit on the trailer(you are
charging the batt while driving) and you run a gen
at the track charging the trailer then you want the
standard batt... if you dont have this stuff you need
the deep cycle.... DONT use the wrong batt if your
not set up for it
Re: TRAILER BATTERY [Re: MR_P_BODY] #1399734
03/10/13 12:37 PM
03/10/13 12:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I have a NAPA deep cycle. keep a battery tender on it in the winter. going on 3-4 years old now/
