BB Water pump which is better 6 or 8 blade? #1398865
03/07/13 10:24 PM
03/07/13 10:24 PM
IN
Dartman928 Offline OP
IN
Guys I have two different water pumps for my BB and was wondering which would be the best oneto use the 6 or 8 blade?
Thank you
Re: BB Water pump which is better 6 or 8 blade? [Re: Dartman928] #1398866
03/07/13 10:45 PM
03/07/13 10:45 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
8 blade ... and saw-off 4 of the blades
Re: BB Water pump which is better 6 or 8 blade? [Re: Dartman928] #1398867
03/07/13 10:48 PM
03/07/13 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 8 blade was considered as the AC pump which flowed more
Re: BB Water pump which is better 6 or 8 blade? [Re: MR_P_BODY] #1398868
03/07/13 11:08 PM
03/07/13 11:08 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Hemi's came with a six blade. The pulley diameter makes a big difference too. I would go with a six blade. I read something about an 8 blade pushing the coolant too fast for the coolant to work effectively or something to that effect? I always had a 6 blade with no cooling problem.
Re: BB Water pump which is better 6 or 8 blade? [Re: Dartman928] #1398869
03/08/13 12:49 AM
03/08/13 12:49 AM
AndyF Offline
AndyF  Offline
Depends on what you're trying to do. 8 blades moves more water,especially at lower speeds. For higher engine speeds the 6 blade would be better, but you might have cooling issues at low speeds. Pulley ratio also matters. The factory engineers had this all figured out which is why there are several different cooling packages depending on the application.
Re: BB Water pump which is better 6 or 8 blade? [Re: Dartman928] #1398870
03/08/13 04:22 PM
03/08/13 04:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Best" depends on how fast you turn the pump, if the pulley ratio drives the pump close to 1-1 the 8-vane is OK but the factory used the 6-vane when they went to 40% overdrive on the pump.
The 8-vane might cause cavitation at higher rpm.
Re: BB Water pump which is better 6 or 8 blade? [Re: AndyF] #1398871
03/09/13 03:26 PM
03/09/13 03:26 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
that's where you get into cooling troubles.. mis-matching pulley sizes and water pumps..
been there.
