Need help with power steering pump #1397968
03/06/13 08:04 AM
03/06/13 08:04 AM
Netherlands
72Challenger Offline OP
Netherlands
Need some help with my TRW power steering pump.
As the (working) pump was leaking I took it out and did a rebuild as in replacing al seals etc. Seemed to be no rpoblem, easy job. But after re-installing it it did work for a moment and later I needed to realy rev the engine to have some power steering.
Anybody have any idea what could cause this?
Thanks a lot!
Re: Need help with power steering pump [Re: 72Challenger] #1397969
03/06/13 08:18 AM
03/06/13 08:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Did you bleed the air out.I usually start them and run the wheel lock to lock.Just hold it on the locks for a few seconds.Sometimes it takes a bit to bleed them.Rocky
Chrysler Firepower
Re: Need help with power steering pump [Re: therocks] #1397970
03/06/13 11:18 AM
03/06/13 11:18 AM
Netherlands
Netherlands
Forgot to mention but I've done that for some time yes.
Thougth maybe there's a certain way the bypass valve / spring should be installed. Was hoping somebody else had this covered in the past...
