Page 2 of 3 1 2 3
Re: Track Day [Re: HUSTLESTUFF] #1396853
03/04/13 12:32 PM
03/04/13 12:32 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Very cool... "MoPower" to ya! Hoperfully you'll get to the May 2013 Spring Fling with the car and run the road course track event with them.
Re: Track Day [Re: B-Body Bull] #1396854
03/04/13 04:29 PM
03/04/13 04:29 PM
NORTHERN CA
HUSTLESTUFF Offline OP
NORTHERN CA
I spun twice, went in too hard and turned while braking and forgot to let out clutch before I started turn.
Now you know why a rear sway bar is not used by some. But if you learn your car,you can adjust and be fast. I'm jealous, (CHARGER !) All I have is a NEON .
No rear bar on the car...just me pushing hard and being new. I do have one video I will try to upload and one of the instructors is supposed to send me some video from front and back.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Track Day [Re: HUSTLESTUFF] #1396855
03/04/13 05:52 PM
03/04/13 05:52 PM
indy
E
edco440 Offline
edco440  Offline
E
indy
Very Nice! Can someone explain using both engine mount sides,(Pass and drivers) from Schumacher? Are you saying to mount BOTH sides?? I have his torque rod setup on my 70 R/T Shaker Hood car on the drivers side,,love it!
Re: Track Day [Re: edco440] #1396856
03/04/13 06:00 PM
03/04/13 06:00 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Yes, BOTH sides.
One rod on the left side of the engine, and one rod on the right side of the engine, AT THE SAME TIME.
Have someone in the driver's seat. Engine running, in gear, parking brake on, his foot HARD on the brakes.
Stand beside the right fender and watch the motormount rubber.
Have the 'driver' punch the throttle.
The rubber will compress and you can see it, expecialy when you have a rod on the left side as the left won't come up hardly, therefore the right HAS to go down and compress the rubber as the engine WILL torque over.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Track Day [Re: amxautox] #1396857
03/04/13 07:01 PM
03/04/13 07:01 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Why not a engine plate at that point? It would also tie the front frame rails together.
A new iron curtain drawn across the 49th parallel
Re: Track Day [Re: 67autocross] #1396858
03/04/13 07:04 PM
03/04/13 07:04 PM
amxautox Offline
amxautox  Offline
Some organizations don't allow plates, or solid mounts.
Tom
author unknown
Re: Track Day [Re: amxautox] #1396859
03/04/13 08:45 PM
03/04/13 08:45 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'm gonna go solid driver side ,poly passenger side.
Mopar to the bone!!!
Re: Track Day [Re: 72Swinger] #1396860
03/04/13 09:22 PM
03/04/13 09:22 PM
San Francisco Bay Area
MrAngry Offline
MrAngry  Offline
That's awesome man! Keep it up!!
Never trust a pretty girl... or a lonely midget.
Re: Track Day [Re: MrAngry] #1396861
03/04/13 10:29 PM
03/04/13 10:29 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I wouldn't call it it "babying it" if your out on a track - props!need some vids!
Re: Track Day [Re: dangina] #1396862
03/05/13 01:33 PM
03/05/13 01:33 PM
NY NY
3
340duster340 Offline
NY NY
thanks for posting the pics and nice ride. what tires are you running and how many laps do you get out of them?
also does your car have head rests? if not i would seriously recommend getting seats with head rest. talk to any paramedic and ask them what a pez dispenser refers to in their line of work.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Track Day [Re: 340duster340] #1396863
03/05/13 05:15 PM
03/05/13 05:15 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
The torque strut needs to be on both sides.
It works, we tested the dual set up hard in 2012.
A solid mount on the driver side and anything on the right will not solve the problem. Solid mounts are not good for the car.
As far a the brakes on the OP's car. Ducted air into real spindle ducts is required for any brake set up. Heat is the enemy. Chargers are easy as you can put the intake duct where the splash shield lives in front of the tire.
Re: Track Day [Re: ThermoQuad] #1396864
03/05/13 05:16 PM
03/05/13 05:16 PM
ThermoQuad Offline
ThermoQuad  Offline
spindle ducts, this really works...
Re: Track Day [Re: amxautox] #1396865
03/05/13 05:38 PM
03/05/13 05:38 PM
indy
E
edco440 Offline
edco440  Offline
E
indy
Yes, BOTH sides.
Thank You,, AMXAUTO Nice brake cooling set-up Tom,, Mitch L. sent me some pics of the Fabbed alloy ones,, very nice. pics on Mopax e-chat Chris Heineys site,,Thanks again Tom!
Re: Track Day [Re: ThermoQuad] #1396866
03/05/13 08:43 PM
03/05/13 08:43 PM
Plainfield, NJ - USA
mustardketchup Offline
Great looking car, HUSTLESTUFF. The car has a great color combo and a great stance. Plus, you get it on the track!
Tom Quad, in particular, always preaches the virtues of extra brake cooling. While poking around on V8Miata.net, I came across a brake thread and some posters were also promoting that same philosophy.
The guy at V8Miata.net added a twist to this concept by using the electric air injection smog pump on his 2002 LS-1 Camaro to provide continuous airflow to the front brakes. This way, the brakes are being force-fed air if the car is moving slowly or even if it is stopped - and he claims it moves a "truckload" of air. His monetary outlay was less than $50; a few bucks more if you use "proper" brake hose ducting.
The poster's build-up of the system was originally posted on LS1Tech.com. Here's that link:
http://ls1tech.com/forums/suspension-brakes/1572847-diy-brake-ducts-less-then-20-bucks.html
I'm also including the V8Miata.net link because a clear picture of the electric smog pump was provided in the post (for those of you who will scour salvage yards):
http://www.v8miata.net/suspension-drivetrain-12/what-brake-setup-you-running-791/
I hope this is helpful to you people who take your cars out to track events.
Lawrence Brady
Re: Track Day [Re: HUSTLESTUFF] #1396867
03/05/13 08:46 PM
03/05/13 08:46 PM
ThermoQuad Offline
ThermoQuad  Offline
Hot brakes are no fun...imagine running 45 minutes a session. I can't imagine running with out a thermostat. We put an external-in front of the core support ps cooler to help take heat out of the engine compartment.
How did you take care of the engine venting?
Here is how you sneak the mounts for the shoulder belts into a charger. Those are the correct eye bolts but what you don't see is the angle iron reinforcement that runs across the inside top of the package tray.
Check out the 3pt seat belt for the kid
Re: Track Day [Re: mustardketchup] #1396868
03/05/13 08:55 PM
03/05/13 08:55 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Lawrence Brady
Nascar even has been running in-line brake duct blowers for a while now. We even run them on our short track car.
Like around $30 each: http://www.circletracksupply.com/brake-ducts-hose/
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Track Day [Re: autoxcuda] #1396869
03/06/13 01:20 AM
03/06/13 01:20 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
Those look like marine engine blowers.
http://www.westmarine.com/webapp/wcs/sto...CFexaMgodc1QAmQ
Re: Track Day [Re: RichV] #1396870
03/06/13 03:40 AM
03/06/13 03:40 AM
NORTHERN CA
NORTHERN CA
Ordered up the Schumacher torque straps today. I vented the car w/ -8 fittings in valve covers and hose into frame rails. On my list is a breather tank. I have a 2 row power steering cooler up front.
I have some brake ducting stuff from when I made a spoiler that I didn't like so I may play with that. Hope to do track day next month.
I couldn't get the video to load had some audio problem and it said 1200 min to load. Slow internet out in the country. But big shop!!! Hopefully the instructor will email me the video he had.
Thanks for the nice comments on the car. Mike
RIP UN
Re: Track Day [Re: HUSTLESTUFF] #1396871
03/06/13 09:57 AM
03/06/13 09:57 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Nice shot of the brake cooling Tom. How does that car do at the Glen with such small brakes? What brakes are you using on the Cuda?
Re: Track Day [Re: BergmanAutoCraft] #1396872
03/06/13 03:45 PM
03/06/13 03:45 PM
NORTHERN CA
NORTHERN CA
I was looking under the car at how the passenger side torque strap would fit...I lost two of the three ARP motor mount bolts. I also lost two of three driver side collector bolts. Lots of stresses.
RIP UN
Page 2 of 3 1 2 3
