Re: Fluidampr with Eagle Crank Problem
[Re: rickraw]
#1396110
03/02/13 11:40 PM
03/02/13 11:40 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
the first mark is from the dust shield.
Dust shield? Is that the oil slinger that stays right up against the lower timing sprocket? I am having a hard time picturing what your saying for some reason
[Re: rickraw]
#1396113
03/03/13 12:23 AM
03/03/13 12:23 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Well here is what started the problem. As you can see the pulley does not line up at all. The post below is a pic of behind the damper, showing what I think, is it not going in deep enough. However, because of the hub length, it can't go in deeper because it is bottoming out on the crank.
RS23L7 4-Speed
[Re: Mopar_Mike]
#1396115
03/03/13 12:42 AM
03/03/13 12:42 AM
Posts: 1,845 Tampa
DusterDave
Tampa
That damper has certainly seen better days. Are you sure that is the right crank pulley?
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: rickraw]
#1396117
03/03/13 01:07 AM
03/03/13 01:07 AM
Mopar_Mike
Danville, NH
yeah, thats a stock 440 pulley with PS. Here is the replacement billet I want to use.
RS23L7 4-Speed
[Re: Mopar_Mike]
#1396118
03/03/13 01:49 AM
03/03/13 01:49 AM
Posts: 4,299 State of Fascism
52savoy
State of Fascism
ok...
A couple questions. With the crank bolt out, is the balancer hole flush with the crank snout or show it can go more?
How thick is the Fluiddamper? It looks pretty wide in your picture. Like maybe a Hemi or BB chevy P/N on the damper?
I've got a couple aftermarket cranks and the snouts are a little oversized. So I had to hone the balancers but sounds like you've got something else happening.
[Re: Mopar_Mike]
#1396119
03/03/13 03:34 AM
03/03/13 03:34 AM
Mopar-Al
Alabama
Mike, If you are planning on running the stock pullies, you need the revised sunken fluid dampner. It will allow you to run the stock stuff.
[Re: Mopar_Mike]
#1396120
03/03/13 12:03 PM
03/03/13 12:03 PM
Posts: 16,936 NC
440Jim
NC
I see the snout on the Eagle crank is about 1.75" while a stock 440 crank is around 2.5".
I agree that old design Fluidamper doesn't allow the stock pullies to line up (no recess for the pulley).
I am wondering about your crank snout info. Is the measurement in this pic what you are talking about? 1.767" plus the crank sprocket thickness of 0.78" = 2.55"?
[Re: Dodgem]
#1396123
03/03/13 01:12 PM
03/03/13 01:12 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Damper looks be be for a 392 Hemi.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#1396124
03/03/13 02:07 PM
03/03/13 02:07 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
If everything else is fine and all you need is a"shorter" pulley check Mike Doty's website. http://www.dotymi.com/Automotive_Home.htmI use the Doty pulley with the other stock pulleys and everything lines up perfectly. This is for ATI dampers though. The difference looks about the same, though so this could be your answer. Here is one with a Doty crank pulley, stock w/p pulley. EDIT: Looking at the pic you posted(side view) it looks like the pulley isnt seated far down enough. Is it the hub? I doubt there is anything wrong with the crankshaft... Maybe its time to drop back and punt. Sell off that FD to someone else, get an ATI and a Doty pulley and you can use all your billet stuff. Problem solved.. MB
[Re: HPMike]
#1396125
03/03/13 05:14 PM
03/03/13 05:14 PM
Mopar_Mike
Danville, NH
Thanks everyone for your responses and help. I think I found the problem...
Don't use parts you know nothing about!
I am buying a new damper!
RS23L7 4-Speed
[Re: Mopar_Mike]
#1396126
03/03/13 05:20 PM
03/03/13 05:20 PM
Quicktree
get yourself an ATI and forget about a fluid damper
[Re: Quicktree]
#1396127
03/03/13 05:21 PM
03/03/13 05:21 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
[Re: Mopar_Mike]
#1396128
03/03/13 05:32 PM
03/03/13 05:32 PM
Posts: 2,091 Delray beach, Florida
Performance Only
That's definately the old style fluidamper. That thing has tobe pretty old because they haven't made them that way for a very long time now. I think someone was making pulley's that would work but don't remember who it was now. Google might help on that. I know if it were something i was building, that damper would become a door stop inn favor of something newer that would also work with the pulley you already own.
machine shop owner and engine builder
