Re: Fluidampr with Eagle Crank Problem [Re: Mopar-Al] #1396109
03/02/13 11:34 PM
03/02/13 11:34 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
the first mark is from the dust shield.
Re: Fluidampr with Eagle Crank Problem [Re: rickraw] #1396110
03/02/13 11:40 PM
03/02/13 11:40 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Dust shield? Is that the oil slinger that stays right up against the lower timing sprocket? I am having a hard time picturing what your saying for some reason
Re: Fluidampr with Eagle Crank Problem [Re: Mopar-Al] #1396111
03/02/13 11:46 PM
03/02/13 11:46 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Mopar-Mike, did you mock this up all the way? What was the distance from the back edge of the balancer to the timing cover? 1/4 inch or 1 inch? 1/4 or a little less is about the correct depth. Even with my KB gear drive and Milodon Gear drive, the space is very small.
Re: Fluidampr with Eagle Crank Problem [Re: Mopar-Al] #1396112
03/02/13 11:53 PM
03/02/13 11:53 PM
Ambridge, Pa.
Ambridge, Pa.
the frt seal has a little seal lip in front of the oil seal. that's why there are 2 marks on the hub.
Re: Fluidampr with Eagle Crank Problem [Re: rickraw] #1396113
03/03/13 12:23 AM
03/03/13 12:23 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Well here is what started the problem. As you can see the pulley does not line up at all. The post below is a pic of behind the damper, showing what I think, is it not going in deep enough. However, because of the hub length, it can't go in deeper because it is bottoming out on the crank.
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396114
03/03/13 12:24 AM
03/03/13 12:24 AM
Danville, NH
Danville, NH
Here is space behind the damper..
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396115
03/03/13 12:42 AM
03/03/13 12:42 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
That damper has certainly seen better days. Are you sure that is the right crank pulley?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Fluidampr with Eagle Crank Problem [Re: DusterDave] #1396116
03/03/13 12:48 AM
03/03/13 12:48 AM
Ambridge, Pa.
Ambridge, Pa.
that's what i was thinking. there is a shorter stock pulley.
Re: Fluidampr with Eagle Crank Problem [Re: rickraw] #1396117
03/03/13 01:07 AM
03/03/13 01:07 AM
Danville, NH
Danville, NH
yeah, thats a stock 440 pulley with PS. Here is the replacement billet I want to use.
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396118
03/03/13 01:49 AM
03/03/13 01:49 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
ok...
A couple questions.
With the crank bolt out, is the balancer hole flush with the crank snout or show it can go more?
How thick is the Fluiddamper? It looks pretty wide in your picture. Like maybe a Hemi or BB chevy
P/N on the damper?
I've got a couple aftermarket cranks and the snouts are a little oversized. So I had to hone the balancers but sounds like you've got something else happening.
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396119
03/03/13 03:34 AM
03/03/13 03:34 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Mike, If you are planning on running the stock pullies, you need the revised sunken fluid dampner. It will allow you to run the stock stuff.
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396120
03/03/13 12:03 PM
03/03/13 12:03 PM
NC
440Jim Offline
440Jim  Offline
NC
I see the snout on the Eagle crank is about 1.75" while a stock 440 crank is around 2.5".
I agree that old design Fluidamper doesn't allow the stock pullies to line up (no recess for the pulley).
I am wondering about your crank snout info.
Is the measurement in this pic what you are talking about?
1.767" plus the crank sprocket thickness of 0.78" = 2.55"?
Re: Fluidampr with Eagle Crank Problem [Re: 440Jim] #1396121
03/03/13 12:16 PM
03/03/13 12:16 PM
NC
440Jim Offline
440Jim  Offline
NC
This pic might help you also.
It is the old style Fluiddamper, but it doesn't have the unboltable part you have. The measurement is from the damper face to the location on the timing cover where the bolt seats (removed bolt for measurement surface).
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396122
03/03/13 12:23 PM
03/03/13 12:23 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That could well be a small block one they are much deeper/longer.
Re: Fluidampr with Eagle Crank Problem [Re: Dodgem] #1396123
03/03/13 01:12 PM
03/03/13 01:12 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Damper looks be be for a 392 Hemi.
Leave the gun.......take the Cannoli's....Mike
Re: Fluidampr with Eagle Crank Problem [Re: mike s] #1396124
03/03/13 02:07 PM
03/03/13 02:07 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
If everything else is fine and all you need is a"shorter" pulley check Mike Doty's website.
http://www.dotymi.com/Automotive_Home.htm
I use the Doty pulley with the other stock pulleys and everything lines up perfectly. This is for ATI dampers though. The difference looks about the same, though so this could be your answer.
Here is one with a Doty crank pulley, stock w/p pulley.
EDIT: Looking at the pic you posted(side view) it looks like the pulley isnt seated far down enough. Is it the hub? I doubt there is anything wrong with the crankshaft...
Maybe its time to drop back and punt. Sell off that FD to someone else, get an ATI and a Doty pulley and you can use all your billet stuff. Problem solved..
MB
Re: Fluidampr with Eagle Crank Problem [Re: HPMike] #1396125
03/03/13 05:14 PM
03/03/13 05:14 PM
Danville, NH
Danville, NH
Thanks everyone for your responses and help. I think I found the problem...
Don't use parts you know nothing about!
I am buying a new damper!
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396126
03/03/13 05:20 PM
03/03/13 05:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
get yourself an ATI and forget about a fluid damper
Re: Fluidampr with Eagle Crank Problem [Re: Quicktree] #1396127
03/03/13 05:21 PM
03/03/13 05:21 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396128
03/03/13 05:32 PM
03/03/13 05:32 PM
Delray beach, Florida
P
Performance Only Offline
P
That's definately the old style fluidamper. That thing has tobe pretty old because they haven't made them that way for a very long time now. I think someone was making pulley's that would work but don't remember who it was now. Google might help on that.
I know if it were something i was building, that damper would become a door stop inn favor of something newer that would also work with the pulley you already own.
machine shop owner and engine builder
