Re: Coronet 440 drug out of woods...scrap or get running?
[Re: Jeremiah]
#1394880
03/05/13 11:20 PM
03/05/13 11:20 PM
moparpollack
Lil Herman
Lil Herman
85086
In reference to the picture above - I am wondering if the steering column is original to the car. Maybe a line worker had a liquid lunch and mistook blue for black?
The column is from a 67 as the wheel is different and the shifter is not all metal and has a plastic end.
[Re: Jeremiah]
#1394887
03/12/13 06:35 PM
03/12/13 06:35 PM
Posts: 629 Michigan
dart1962_440
Floors are prepped for a top coat. I had to patch over a few small holes but overall not too bad.
Looks great! How did you patch over the few small holes. I'm looking to do something similar. Thanks
[Re: dart1962_440]
#1394888
03/13/13 11:08 AM
03/13/13 11:08 AM
Posts: 9,106 Rogue River, OR
Jeremiah
Rogue River, OR
Thanks guys...more pics to come soon. I used some light gauge steel and formed it to the two area's where the floor was a little thin with a ball peen hammer. I then used a heavy weight epoxy and glues the patches to the floor. It's not the best way to go but the metal is too think to weld (I think?) and the biggest hole was only the size of a quarter and not enough to replace the floor pan. I keep reminding myself not to go overboard on this one. Hopefully I can get the inside of the roof, trunk and roof itself prepped and painted before our legendary order shows up. I have blasted and painted all of the seat frames, seat brackets, etc. and have them in paint now. ![](/ubbthreads/images/graemlins/thumbs.gif) I sure hope the engine and trans are ok lol Almost forgot..the gas tank and filler neck are ready to be picked up at the shop that cleaned them up so it's time to test the sndeing unit and order the replacement rubber parts.
[Re: Jeremiah]
#1394889
03/13/13 06:04 PM
03/13/13 06:04 PM
Posts: 629 Michigan
dart1962_440
Can you post a close up pic of the finished work please? Thanks
