door window rattle when down #1393497
02/25/13 08:53 PM
02/25/13 08:53 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
My 74 scamp glass seems loose when its rolled all the way down. There dosnt seem to be anything to hold it remotely snug when the window is all the way down. Am I missing something? It seals great when up and goes up and down fine... just verly loose back an forth toward the inside and out when all the way down.
Re: door window rattle when down [Re: mopfried] #1393498
02/25/13 10:17 PM
02/25/13 10:17 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Sounds like its off at the bottom of the track. Can you grab the top edge of the glass and pull it upward significantly? If you can do that, I'd say the large plastic rivet that holds the window to the track has broken and fallen away. Time to pull the door panel for a peak at what's happening.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: door window rattle when down [Re: GO_Fish] #1393499
02/25/13 10:21 PM
02/25/13 10:21 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
no, it dosent move up and down only back and forth toward the inside and outside of the door.
Re: door window rattle when down [Re: mopfried] #1393500
02/25/13 10:24 PM
02/25/13 10:24 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
pop door panel and top plastic piece off, under plastic piece should be a grey/silver bracket almost the length of the door, it should had little rubber pieces that press against glass, you may have to loosen bolts and press the bracket against the glass and tighten and test.
Re: door window rattle when down [Re: MonGoo$e] #1393501
02/25/13 11:54 PM
02/25/13 11:54 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I tried that,,, then the glass is too tight and wont go all the way up. It seems its going down too far. Is there a way to control how far down it goes?. Its going below the weatherstrip. It seems like if it would stay up where it was touching the weatherstrip it wouldnt be so loose.
Re: door window rattle when down [Re: mopfried] #1393502
02/27/13 12:47 AM
02/27/13 12:47 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Is there supposed to be a rubber bumper attached to the bottom of the door frame to limit the downward travel? I have a 70 service manual that shows some type of bumper... the 70 tracks are completely different than the 74...
Re: door window rattle when down [Re: mopfried] #1393503
02/28/13 09:21 AM
02/28/13 09:21 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
They rattled when the car was brand new....
Re: door window rattle when down [Re: floridian] #1393504
02/28/13 09:48 AM
02/28/13 09:48 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
not sure about the a body but on b bodies, there is a rubber stop in the bottom of the door to prevent it going down to far
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: door window rattle when down [Re: floridian] #1393505
02/28/13 10:20 AM
02/28/13 10:20 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
LOL
Re: door window rattle when down [Re: pnypwr] #1393506
02/28/13 10:21 AM
02/28/13 10:21 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Anyone know what they look like? Or where they go?
