Re: Max lift for Magnum/LA Hybrid.
[Re: 71Polara383]
#1393362
02/26/13 09:31 AM
02/26/13 09:31 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
The 408 that I'm getting has a .672 lift solid roller. I'm unclear as to what rocker ratio it's using though. Still some unknowns about it but it does have the aluminum MP magnum R/T heads.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 540challenger]
#1393364
02/26/13 10:47 AM
02/26/13 10:47 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
It depends on how the heads are done. On a sotck magnum head once you get past the .500 lift mark you need to have the guides clearance. Just bring your heads to any decent machine shop and tell what lift you are going to use and they will make them work.
even with that you have limitations....so far the best moderate rate and cost spring I've found is the Hughes #1110....coil bind height is 1.040", rate is IIRC ~350lb/in, cost about $95. with 2.2L retainers and stock magnum locks, you'll get around 1.6-1.62" IH, so I'd keep lift below about .525"
