Lower control arm clunk from pivot point, fixable? #1392934
02/24/13 04:32 PM
02/24/13 04:32 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
My 1970 Challenger had a clunk when shifting from forward to reverse. The right LCA may have excessive wear at the pivot point between the torsion bar adjuster and the outer housing. Can I successfully squeeze the two outer parts against the pivot shaft in a press or is this LCA scrap? I really hate to replace it because they have the boxing plate welded in and sway bar mounts.
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392935
02/24/13 04:34 PM
02/24/13 04:34 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
Look here for what you need.web page
Re: Lower control arm clunk from pivot point, fixable? [Re: gregn96cuda] #1392936
02/24/13 04:52 PM
02/24/13 04:52 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
That is exactly what I thought the problem might be. The flex on the right side is worse than the left but after watching the video neither of them are as bad as the ones that Jim fixed. Both of mine are tighter than after Jim's the repair. Now I'm wondering if that isn't the cause of my clunk. The bushings are relatively new and there is zero play in them so I'm scratching my head.
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392937
02/24/13 05:12 PM
02/24/13 05:12 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Check the tubes in your K frame for cracking around the weld areas.
Strut rod bushings too.
Re: Lower control arm clunk from pivot point, fixable? [Re: RobX4406] #1392938
02/24/13 06:07 PM
02/24/13 06:07 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Thanks, cleaned and checked the tube but no apparent problems. Weld is solid.
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392939
02/24/13 07:29 PM
02/24/13 07:29 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
I have had bad u-joints "clunk" when going from forward to reverse and vise versa. Why do you suspect the control arm?
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392940
02/24/13 09:15 PM
02/24/13 09:15 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Check your strut rod bushings.
Re: Lower control arm clunk from pivot point, fixable? [Re: GODSCOUNTRY340] #1392941
02/24/13 09:42 PM
02/24/13 09:42 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, you can tighten the halves of the LCA around the pivot housing.
BUT there still can be wear between the OD of the pivot housing and the halves of the LCA stampings. Tightening the halves together will not fix that looseness.
I have that problem with my LCA's. I clamped and weded the halves together in the above picture about 16 years ago in 1997. But now there is noticable movement between the pivot housing and LCA stampings.
This is the same set of LCA's as pictured above on the left, just painted black and 16 years later...
Re: Lower control arm clunk from pivot point, fixable? [Re: larry4406] #1392942
02/24/13 10:42 PM
02/24/13 10:42 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Funny you mention that. I am starting to wonder if the clunk was not LCA related but I've eliminated several other potential problems. The U joints and the trans yolk were both toast and causing 'other' clunks. Those got fixed last year.
Strut rod bushings are poly and fairly new. Have them out too but no apparent wear or problems.
Autoxcuda, yes I was wondering about the tolerance on that as well. Mine don't seem exceptionally worn but there is some play. Wondering if a few choice blows with a chisel all around the circumference would stake the outers into the inner. That fix might be only temporary if it worked at all.
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392943
02/25/13 12:04 PM
02/25/13 12:04 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
How do you know it's the control arms ? Do you feel the clunk in the steering wheel ?
How much backlash is in the rear end ? Is the car an auto or 4 speed ?
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392944
02/25/13 12:12 PM
02/25/13 12:12 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
That's usually strut rods. Check the big nut torque, perhaps the bolts to the LCA. any big clunks from the axle between coast down and putting power on? (backlash?)
KFrame loose? (yikes). Sector shaft loose? Idler arm?
Transmount?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392945
02/25/13 12:33 PM
02/25/13 12:33 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Watch this video...
http://youtu.be/Nwes-SP8u4w
Re: Lower control arm clunk from pivot point, fixable? [Re: Jim_Lusk] #1392946
02/25/13 12:39 PM
02/25/13 12:39 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
heh, arc welding with exposed skin...
Re: Lower control arm clunk from pivot point, fixable? [Re: VincentVega] #1392947
02/25/13 12:47 PM
02/25/13 12:47 PM
JohnRR Offline
JohnRR  Offline
Working on his tan , I do it all the time ...
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392948
02/25/13 02:02 PM
02/25/13 02:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You can pinch the back and weld a strap to hold it like I pictured. I don't think a few blows around that circumfernce would hurt anything. That's a good idea. And if the noise went away and came back, at least you could narrow down the source better (I'd chisel it again in the car to see if it would go away again to confirm). And/or you could also put lube in the circumfernce joint and see if that gave any temporary change.
Re: Lower control arm clunk from pivot point, fixable? [Re: autoxcuda] #1392949
02/25/13 02:56 PM
02/25/13 02:56 PM
RobX4406 Offline
RobX4406  Offline
Be careful with pull from welding if putting straps across the arms.
Re: Lower control arm clunk from pivot point, fixable? [Re: VincentVega] #1392950
02/25/13 08:48 PM
02/25/13 08:48 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I don't do a lot of welding so I don't worry much about it. It's the shoes that catch on fire that make it real fun....
Re: Lower control arm clunk from pivot point, fixable? [Re: Jim_Lusk] #1392951
02/26/13 02:03 PM
02/26/13 02:03 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
The straps look like a great idea. I'm going to add the straps and then heat and beat the outer shell. There goes my OE Gold Certification!
You guys are making me feel guilty so I guess I better dig out my welding jacket and find some shoes that aren't made out of nylon.
Re: Lower control arm clunk from pivot point, fixable? [Re: conv440] #1392952
02/26/13 02:14 PM
02/26/13 02:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You won't need to heat the shell. Just clamping it in a vise near the end will tighten it to however tight you set the vise at.
Re: Lower control arm clunk from pivot point, fixable? [Re: autoxcuda] #1392953
02/26/13 02:20 PM
02/26/13 02:20 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
I was going to heat the metal and give a few whacks to the rear outer shell to try to close the tolerance between the torsion bar mount and the rest of the arm. Same place you are experiencing some slop in your earlier post (looseness/gap/wear).
