NE1 fab their own radiator shroud?
#139145
10/20/08 02:07 PM
10/20/08 02:07 PM
Posts: 571 central PA
mopartial
central PA
I cant find aftermkt shroud or even rad with shroud without going to elec which Id rather not. JY access here is nil. Im thinking of fabricating, probably with fiberglass...
Any thoughts?
If it aint broke, dont break it.
Re: NE1 fab their own radiator shroud?
[Re: mopartial]
#139146
10/20/08 03:12 PM
10/20/08 03:12 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Any thoughts?
Unfortunately, I don't have any pictures but made one for my 56 D100. Started by making a ring the circumfrence of my fan rotation + about 1/2" out of cardboard and I mocked up the rest, also from cardboard. Then cut the pieces out of HVAC sheet metal and pop riveted together. Painted and installed. A little time consuming and a sheet metal break would have made things a bit easier, but it turned out pretty good if I do say so myself
