Re: 904 trans died behind 390 stroker, time for 727????
[Re: tpabayflyer]
#139071
10/23/08 09:53 AM
10/23/08 09:53 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I have installed a lot of transgo shift kits tf1 and tf2s in factory VBs and never had one free wheel in 1st.Factory Vb has low band apply in manual 1st. Unless you used a tf3 that is full manual and I dont remember if they free wheel in manual 1st or not its been to long on that one.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dustpan man]
#139075
10/24/08 06:50 AM
10/24/08 06:50 AM
sounds like a vavle body problem
thats what I thought of too. the valves can wear out over many many miles. Or some crap got in there and is blocking something.
I put aB&M shift kit in mine many years ago and it performed great. then the car sat for several years. I just put together a motor and started driving it again and after a few hundred miles, mine started freewheeling when I downshifted to first.
I changed out the valve body for a Turbo Action Cheetah manual/automatic valve body and everything is GOOD, and I mean real GOOD, now. shifting is tight, and problems went away
[Re: patrick]
#139077
10/24/08 08:42 AM
10/24/08 08:42 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
[Re: tpabayflyer]
#139078
10/24/08 11:14 AM
10/24/08 11:14 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
I think it was the TF-1 kit but remember this is a lockup converter valve body.......It has an S-bend tube on the top..... Even before I messed with anything drove the car with the stock 318 2bbl the trans would freewheel in 1 st gear. I remember it would not provide engine breaking in 1st gear but I thin it would if i held it down in first... it would freewheel when left in drive???? TBF
Might be an issue with the over running clutch ? The lockup convertor and it's fluid path should have ZERO effect on first gear operation .
[Re: AdamR]
#139080
10/24/08 07:27 PM
10/24/08 07:27 PM
Posts: 296 CT
turbocolt2.4L
CT
904 + 450+ hp =
OUCH I have 480 hp to the rear wheels with a 4cyl turbo car and run a 904 w/brake with no major problems,just took out the sprag but had over 130 pulls on the chassis dyno and 4 hard passes at the track 904's can take a beatin.........
[Re: turbocolt2.4L]
#139082
10/25/08 09:29 AM
10/25/08 09:29 AM
JohnRR
A gulag near you.
904 + 450+ hp =
and that colt weighs HOW MUCH ??? 904 will live just fine bolted to a ROLLER SKATE ...
[Re: babarracuda]
#139085
10/25/08 03:18 PM
10/25/08 03:18 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
My tow vehicle is a '89 3/4 ton van with the 999 with lock up (hd 904). I've had it for 11 years and towed locally and made a few trips towing out of town. It was still towing fine but started leaking bad out the front seal and it stopped locking up. Had it rebuilt while it was out for the front seal fix and put in a new converter.
Last week we towed to Elk Creek Dragway, about 70 miles one way and up and down a couple of steep mountains. No problems. It towed like a champ.
Race car and open trailer weighs about 4900 lbs.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
