Re: Advice on the old L2355 TRW 440 Slugs
[Re: 80fbody]
#1389688
02/18/13 02:12 PM
02/18/13 02:12 PM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
I did something similar a few decades ago and had to have them flycut for a .590 cam.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 80fbody]
#1389689
02/18/13 02:15 PM
02/18/13 02:15 PM
Posts: 1,509 TN
SCATPACK 1
TN
I have thos eold TRW pistons in my motor too. IF I had it to do over again, I would buy a set of newer pistons using new metal technology, so I could have ran them tighter for better rign seal and less piston skirt slap. I hate how noisy and heavy these are. And YES, I had to notch them just to run a 257 @ 50 cam. I also had to cut my block to get them to zero deck. I am nOT happy with them, nope not at all. Mine still had all of the paperwork with them and were in the original box. So I had the machinist set them to what the paperwork desired. And I double checked all measurements when I got the block back home. These were OK 40 years ago, but too many affordable options today to waste money on this old piston. A buddy bought a set of KB Hyperutectic pistons and has less in them than I did in the machine work to make these work. Just saying. Good luck with it either way you decide to go.
Old Geezer Racing
[Re: SCATPACK 1]
#1389690
02/18/13 02:49 PM
02/18/13 02:49 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I used those same pistons in motor that I built nearly 30 years ago! It was not balanced or blueprinted, just bored, new pistons, rings and bearings, with stock valve 906 heads with stock ports. At the time I could not afford the professional touch. I worked up to the DC 296/557 cam and it ran strong. In a 3650# B-body with 727 (340 converter) and Dana 60 with 4:88 it ran consistent 12.0s and dipped into the 11.50s with a 125 Nitrous shot. I could not tell you how close the valves were to the pistons, never had reason to take it apart. Would I do it again...NO! I would use lighter pistons and spend the money for professional assembly.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 80fbody]
#1389691
02/18/13 03:38 PM
02/18/13 03:38 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Give them .006 piston to wall clearance (or a tad more they swell like crazy). I had mine zero deck and never had to deepen the fly cuts till I got .085 off my heads with a Ultradyne 263/271 @ .050 .597/.620 lift with 906 heads! Then we milled the heads another .020 for a total of .105 A .557 should be way fine!
Later Indy SR heads with .060 off was way cool also!!
[Re: 80fbody]
#1389693
02/18/13 08:54 PM
02/18/13 08:54 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I ran these in my old motor, with an R280 roller cam .280 dur, 670 lift, 76cc edelbrock heads, no clearance problems, despite the small reliefs. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: mosweethemi]
#1389698
02/19/13 04:03 PM
02/19/13 04:03 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
the old DC and mopar performance books tell that they or good for a 590 cam,
R U saying ... that they said that the OEM fly-cuts in the pistons are good for a 590 ?
