Re: What is the towing rating with a 4 speed W200?
[Re: 76dodgeboy]
#1385996
02/12/13 10:17 AM
02/12/13 10:17 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
Pulling isn't going to be the problem, and you aren't going to hurt the 4 speed as long as its full of oil....stopping will be more of an issue, truck and trailer brakes need to be good. Dad used to haul around a 10 ton tile machine, MF backhoe, and other tractors on a very heavy gooseneck with a 400 4speed, back in the day.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: MMiller]
#1385997
02/12/13 11:25 AM
02/12/13 11:25 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I was going to say that 4 speed is a pretty tuff trans.....I can't comment on pulling a bulldozer though.
I could be wrong, but I don't think I've seen a failure in one.......compared to a 727. Which I realize that doesn't mean anything really.
I wonder why they would have had you say that?
I've been told by horse people that the only reason that they don't like standard trans is if not shifted right then the horses get jerked around.
Moparlee
[Re: Kern Dog]
#1385999
02/12/13 11:48 PM
02/12/13 11:48 PM
Posts: 10,646 Freeport IL USA
poorboy
Freeport IL USA
I towed a 62 Chrysler 300F on my open car trailer with a 440 powered 727 trans, 4:10 heavy duty 3/4 ton extended cab Dodge. 16,800 lbs across the DOT scales, through the mountains in PA. Even with the massive disc brakes in front, 12" x 3" drums out back and with trailer brakes, it didn't like the 6%, 6 mile long down hill stretch! The 440 wasn't too happy climbing the front side either. That trip was the beginning of the end for the old truck. The motor started using oil, the trans would slip going into 3rd, and the brakes must have gotten glazed over because the brakes didn't seem as good as before that trip. Worst part was it made me go get a real job, at least for a couple years.
I never heard the granny 4 speeds had a lighter towing capacity, I always expected a higher towing ability from the 4 speed, less trans slip. Gene
