Re: 1968 GTS 383
[Re: dart4forte]
#1816463
05/01/15 04:04 PM
05/01/15 04:04 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Looks good. I am use that for the LCA's on the Bee. I was wondering what to use when I rebuild them. The last ones I did were powder coated black. That would be the way to go if you are looking for that look I'm just looking for them not to rust instantly. Look is really low on the list of criteria. Mine will never be what most people consider "nice".
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: 1968 GTS 383
[Re: dart4forte]
#1817797
05/03/15 04:44 PM
05/03/15 04:44 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Well, yesterday afternoon I tweeked on the car a bit hooking up wiring, getting the radiator ready to install etc.. I decided to go ahead and move the heater motor plate so that the cutout faces the driver side as suggested. I'm glad the issue was brought up in that when I went to remove the plate I found the heater motor to be loose. Not good. So, tomorrow I'm removing the heater box to se what's going on with that.
Oops!!! forgot the metal spacers. Too much stuff to remember sometime
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1824478
05/11/15 09:09 PM
05/11/15 09:09 PM
dart4forte
Mesa, Arizona
Had the last 4 days off and got quite a bit done. Wanted to get the dash put together for install
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1829830
05/19/15 03:40 AM
05/19/15 03:40 AM
dart4forte
Mesa, Arizona
Another update. Got the dash in. Went right in. Tackled the wiring today. I'm waiting on some cable clips from R/T Specialties before I proceed. Buddy of mine with an automotive electrical shop will be coming over to check all the circuits
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1832470
05/22/15 09:31 PM
05/22/15 09:31 PM
dart4forte
Mesa, Arizona
Dash is pretty much done. Got the ebrake mechanism in place. Car is on the lift again for exhaust install, ebrake lines and generally tightening things up. Greasing the suspension and adding fluids to the rear end is also on the agenda.
Also the quarter windows are in. Side window mechanisms are next. More pics to follow tomorrow.
Abe Lincoln
Re: 1968 GTS 383
[Re: Hemiken]
#1832691
05/23/15 09:05 AM
05/23/15 09:05 AM
OhioMopar
Mt.Gilead, Ohio
This is a sweet build, looking amazing. Thank you for sharing. Yeah, what he said!
Re: 1968 GTS 383
[Re: dart4forte]
#1833053
05/24/15 12:38 AM
05/24/15 12:38 AM
dart4forte
Mesa, Arizona
Here's the results of todays activities. Got the exahust a mocked up, not quite finished. I need to contact Accurate and get some hangers so I can get everything hung correctly.
Got the front sway bar on but not sure if its correct. I'll be sending some pics to Firm Feel asking for their advise.
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1833055
05/24/15 12:39 AM
05/24/15 12:39 AM
dart4forte
Mesa, Arizona
Also got the calipers mounted. I'm waiting on soem new bolts. Probably have them Tuesday
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1833056
05/24/15 12:41 AM
05/24/15 12:41 AM
dart4forte
Mesa, Arizona
Sway bar doesn't look quite right
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1834294
05/26/15 01:05 AM
05/26/15 01:05 AM
dart4forte
Mesa, Arizona
Finished up the weekend instaLLING the new E brake cables
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1834296
05/26/15 01:07 AM
05/26/15 01:07 AM
dart4forte
Mesa, Arizona
Glad thats done. Now hook up the e-brake under the dash
Abe Lincoln
Re: 1968 GTS 383
[Re: NV69B7RR]
#1834633
05/26/15 04:21 PM
05/26/15 04:21 PM
dart4forte
Mesa, Arizona
As soon as the side window are installed the inetrior is next.
Abe Lincoln
Re: 1968 GTS 383
[Re: dart4forte]
#1834658
05/26/15 05:10 PM
05/26/15 05:10 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Sway bar doesn't look quite right Looks like it's upside down. The hump at the front should be up, not down. The sway bar should go over the top of the K-member to rad support brace.
