Re: For Guys Lowering With Van Control Arms
[Re: Jwilli500]
#1384097
02/09/13 09:52 PM
02/09/13 09:52 PM
Posts: 1,357 central Florida
VL21
central Florida
I had the same thought, hate to make the hole bigger.
But I'm not sure where to get the tube ...
since we had the same thought ...GREAT IDEA!
What is that saying? Great minds run in the same gutter?
It takes gasoline to interest me.
[Re: C_Notch]
#1384099
02/10/13 01:19 AM
02/10/13 01:19 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I havnt looked at mine so Im not sure but if the OD of the van bushing is the same as the truck why not install truck bushings in the van LCAs?
I am truckless..
[Re: 340SHORTY]
#1384100
02/10/13 01:49 AM
02/10/13 01:49 AM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
They're not the same O.D. plus it was only $6 to make these. How much to replace the bushings? From NAPA's website... Van O.D. = 2.06" and I.D. =.76" 3/4 & 1 ton truck O.D. = 1.70" and I.D. = .76" 1/2 ton truck O.D. = 1.40" and I.D. = .63" Quote:
[Re: VL21]
#1384101
02/10/13 02:00 AM
02/10/13 02:00 AM
Jwilli500
Oklahoma City
LOL I've had this idea for awhile but havent been able to look into it completely till now. I bought 3 foot of it which should yield 5 pairs of sleeves. I got my tube at http://www.onlinemetals.com/merchant.cfm...amp;top_cat=197Quote:
[Re: Jwilli500]
#1384106
02/10/13 12:49 PM
02/10/13 12:49 PM
VL21
central Florida
Thanks! That is great they are willing to sell small quantities, I figured I would have to buy a much longer stick of it. I have bookmarked it!
[Re: Evil Spirit]
#1384109
02/10/13 06:21 PM
02/10/13 06:21 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
And to really think outside the monkey cage - that same material could be used to return frame rails that had been drilled (to 3/4") back to their original size! A couple thin slices of the tubing welded into the holes would shim them back to 5/8" hole dia. Who-da-thunk-it...
Suppose that could be done, but by the time you went through the process of cutting the tubing to length and welding it into the enlarged frame holes, you might just as well lay a weld bead all around the hole and drill it out fresh. Holding such a thin piece of tubing into a hole in the frame would be a pita, and you will likely have to dress up the new hole anyway.
I pretend to be a welder in real life. Gene
