70 Dart Rear height? #138383
10/18/08 02:54 PM
10/18/08 02:54 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I just installed the new rear springs on my 70 swinger and it still looks a little low to me.
Does anyone have the correct height for the rear of the car? I am measuring about 21" from the ground to the center of the wheel lip.
Re: 70 Dart Rear height? [Re: Dart 340] #138384
10/19/08 01:42 AM
10/19/08 01:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
All I can do is show you a pic of my sons Dart with my 63. Maybe this will give you an idea on how it should sit. Ron
Re: 70 Dart Rear height? [Re: 383man] #138385
10/19/08 01:53 AM
10/19/08 01:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a better pic. He has the 002 & 003 SS springs on it. Ron
Re: 70 Dart Rear height? [Re: 383man] #138386
10/19/08 08:10 AM
10/19/08 08:10 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Heres mine, 225-70-14s on the rear. I believe they are stock springs bt theres some funky coil over shocks on it.
Re: 70 Dart Rear height? [Re: AdamR] #138387
10/19/08 02:00 PM
10/19/08 02:00 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I have standard shocks (kyb) on mine and it looks
like I have about an inch from the top of the rim
to the wheel well. Yours is sitting about an inch
higher than mine is. Anything else in the suspension
cause this?
Re: 70 Dart Rear height? [Re: Dart 340] #138388
10/19/08 07:22 PM
10/19/08 07:22 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
He's got coil over shocks mine does too, sits lower than his, but my springs are worn out. Standard shocks on the will drop it an inch or so.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: 70 Dart Rear height? [Re: 70dart360] #138389
10/19/08 07:36 PM
10/19/08 07:36 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Here is a page with some scans of the original brochures. It might help to give you an idea of how they sat when new.
http://www.foundationpc.com/brochure/index.htm
Re: 70 Dart Rear height? [Re: 70dart360] #138390
10/19/08 08:10 PM
10/19/08 08:10 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I hope it drops an inch with regular shocks. I think it sit a little to high myself. Yous sits perfect.
Re: 70 Dart Rear height? [Re: 70dart360] #138391
10/19/08 08:17 PM
10/19/08 08:17 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I have about an inch or so of tire showing above
the top of the rim on mine, so I guess it kind
of looks like yours. Maybe I am just used to looking at my jeep too much?
Re: 70 Dart Rear height? [Re: AdamR] #138392
10/20/08 10:37 AM
10/20/08 10:37 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I like a little rake to a Dart. I think maybe I
am too used to how my 'Cuda looks and the Jeep
I have of course it jacked up.
Re: 70 Dart Rear height? [Re: AdamR] #138393
10/23/08 01:21 PM
10/23/08 01:21 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I talked to ESPO about re-arching the springs which they will do for free, but shipping will be over 100 bucks. Am I better off trying the coil over shocks to get that inch or so back or have them re-arch the springs?
Re: 70 Dart Rear height? [Re: Dart 340] #138394
10/23/08 01:30 PM
10/23/08 01:30 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Old and new using XHD springs.
Re: 70 Dart Rear height? [Re: RobX4406] #138395
10/23/08 02:04 PM
10/23/08 02:04 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I'd be happy with that. I am closer to your old
than new. What are you using for shocks?
Re: 70 Dart Rear height? [Re: RobX4406] #138396
10/23/08 03:30 PM
10/23/08 03:30 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Rob, new is the first picture ?
Re: 70 Dart Rear height? [Re: AdamR] #138397
10/23/08 03:54 PM
10/23/08 03:54 PM
RobX4406 Offline
RobX4406  Offline
New is the first pic.
Shocks are cheap gas shocks
Re: 70 Dart Rear height? [Re: RobX4406] #138398
10/23/08 04:07 PM
10/23/08 04:07 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
My ESPO's are in between the two. I like the rake of your new springs. I might have to get mine
arched up an inch or two....
Re: 70 Dart Rear height? [Re: Dart 340] #138399
10/23/08 07:16 PM
10/23/08 07:16 PM
MNobody Offline
MNobody  Offline
My 68 is 23.5 with 26" tires and I believe SS springs.
oops it has adjustable shackles and it's in the 3rd hole so that probably put's it up higher too, also Competition engineering adjustable shock's.
Re: 70 Dart Rear height? [Re: MNobody] #138400
10/23/08 07:21 PM
10/23/08 07:21 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Here's mine.
Re: 70 Dart Rear height? [Re: AdamR] #138401
10/24/08 05:11 PM
10/24/08 05:11 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Adam,
Yours will drop at least an inch when you get the bumper etc. installed and have 150 lbs of fuel in your tank.
Re: 70 Dart Rear height? [Re: Dart 340] #138402
10/24/08 05:17 PM
10/24/08 05:17 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
This is where mine sits. I guess it's not too bad,
but I was expecting it to sit higher with new springs as it will settle some.
