Plenum gasket. 97 ram 1500 with 5.9l #1382073
02/05/13 05:39 PM
02/05/13 05:39 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
While we cleaned the tb on the truck and installed a new IAC sensor we noticed a little oil sitting under intake. I know the cause is a leaking plenum gasket. I just wanted to know what to expect while changing it, what special tools i may need, what to replace while everything is tore out, who makes the best gasket so I dont have to do this again. Thanks in advance Eric
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: Plenum gasket. 97 ram 1500 with 5.9l [Re: Biggie] #1382074
02/05/13 10:38 PM
02/05/13 10:38 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Mopar now uses a stamped steel gasket that will not push out and leak. Pretty staight forward to change it. Be careful with the intake bolts next to the water passages in the heads thay are prone to corrode and sometimes twist off durring removal. Might wanna pick up some new bolts before you start.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Plenum gasket. 97 ram 1500 with 5.9l [Re: Biggie] #1382075
02/05/13 11:50 PM
02/05/13 11:50 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
Get this - problem solved!
http://www.ebay.com/itm/DODGE-JEEP-ALUMI...e2b&vxp=mtr
For concise information on the plenum issue and numerous details on the repair, go here:
http://dodgeforum.com/forum/2nd-gen-ram/286307-end-all-be-all-plenum-thread.html
Re: Plenum gasket. 97 ram 1500 with 5.9l [Re: AtomicDog] #1382076
02/06/13 11:46 PM
02/06/13 11:46 PM
Waterbury, CT
RamMan89 Offline
RamMan89  Offline
Waterbury, CT
My brother just did one on his V8 Grand Cherokee, it's not a quick job but by no means difficult. Only problem he had was breaking some of the 20 year old vacuum lines.
2004 Dodge Ram 3500 Cummins Diesel
1989 Dodge Power Ram W-150
