Closed knuckle front axles. #1380147
02/02/13 06:45 AM
02/02/13 06:45 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I was checking out a '73(I think) 1-ton Dodge truck that had Dana 70's front and rear. Of course the front axle is a closed knuckle, drum brake axle. Is there any way to convert it to disk? Has anyone been in one?
I would imagine they are pretty stout pieces, but drum brakes on a truck used for hauling/towing would kinda scare me.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Closed knuckle front axles. [Re: OhioMopar] #1380148
02/02/13 01:17 PM
02/02/13 01:17 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
My old 73 one ton 4x4 wrecker [factory retriever canfield wrecker body] worked just fine with drum brakes. I dont know about a conversion. Not to many front ends around with that design. I would look for a 75 to 93 one ton front and just bolt it in.
Re: Closed knuckle front axles. [Re: NITROUSN] #1380149
02/02/13 02:56 PM
02/02/13 02:56 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
My old 73 F250 HiBoy had a D44 closed knuckle front axle. At that time there were no disc conversions available..
I am truckless..
Re: Closed knuckle front axles. [Re: 340SHORTY] #1380150
02/02/13 03:01 PM
02/02/13 03:01 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
I think conversions have been cobbled, but it really isn't worth the time, expense or trouble compared to swapping a more modern axle under there.
Re: Closed knuckle front axles. [Re: Cooter] #1380151
02/02/13 03:14 PM
02/02/13 03:14 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
It seems like the parts you want used to be advertised on the following website. I didn't see them listed today, but it may be worth contacting this guy to see if he can help you. (I've never bought anything from him)
http://uglytruckling.com/index.htm
If you find the parts somewhere, please post back. I want to convert my axle also.
Re: Closed knuckle front axles. [Re: QuickDodge] #1380152
02/02/13 06:42 PM
02/02/13 06:42 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just get a D60 and call it good. But it you debt plan on beating the not out of it an 80-93 D44hd from a 3/4 1-ton will work just fine. 75-79 are Full time axles with bad bearing design. No Lockout But you can swap outer shaft and knuckle out on a full time with a part time
Pics
Re: Closed knuckle front axles. [Re: 76dodgeboy] #1380153
02/02/13 07:01 PM
02/02/13 07:01 PM
N
N
Not on HD 3/4 and one ton.
Re: Closed knuckle front axles. [Re: NITROUSN] #1380154
02/02/13 08:45 PM
02/02/13 08:45 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
My 70s D60s beg to differ. No Lockout. Yes lockout can be installed witch I forgot about but still full time setup.
As for the bearings I was referring to the D44hd
Re: Closed knuckle front axles. [Re: 76dodgeboy] #1380155
02/02/13 08:58 PM
02/02/13 08:58 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Pics
I didn't buy it yet. Was exploring the options with a drum brake front end.
You will never find me putting a 44 under anything, especially if equipped with a real axle originally. I've seen them destroyed by a warmed over 360 and a stick. I've personally.destroyed one with a bone stock '69 440 and a stick. 44's are for 1/2 tons and automatic transmissions...
Re: Closed knuckle front axles. [Re: OhioMopar] #1380156
02/02/13 10:57 PM
02/02/13 10:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I haven't had the pleasure of beating a 4wd bad yet. But I have D60s for mine and the wifes clubcab shortbox powerwagons. Both will be bigblocks. Mine a 4spd and hers in the end a 518 but 727 until than. Than I have a D60 that might find its way under my plow truck. My clubcabs hubs are bad and so is another truck I have.
Re: Closed knuckle front axles. [Re: 76dodgeboy] #1380157
02/02/13 11:25 PM
02/02/13 11:25 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Oh, they weren't beaten bad. Except for maybe the 360 truck. It was plowing snow. I don't get why they put 44s under a sno-commander.
My big block truck broke playing in the mud. Never thought I could break something when the wheels were spinning. I was wrong.
Re: Closed knuckle front axles. [Re: OhioMopar] #1380158
02/03/13 12:05 AM
02/03/13 12:05 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Pics
Then you don't want a closed knuckle D70. Tracta Steering Joints aren't really your friends here.
Re: Closed knuckle front axles. [Re: Cooter] #1380159
02/03/13 12:28 AM
02/03/13 12:28 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Pics
Ouch
I am truckless..
Re: Closed knuckle front axles. [Re: 340SHORTY] #1380160
02/03/13 03:16 AM
02/03/13 03:16 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Pics
Ouch
Noted!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Closed knuckle front axles. [Re: OhioMopar] #1380161
02/03/13 04:35 PM
02/03/13 04:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
That looks like an older Dodge hypoid axle joint. Closed knuckle D70's have regular joints or was that from a late 50's Power Wagon D70?
Re: Closed knuckle front axles. [Re: Defbob] #1380162
02/03/13 04:46 PM
02/03/13 04:46 PM
N
N
My 73 w-300 had that goofy pieced together affair. The smaller 3/4 and 1/2 tons had u-joints as I recall.
Re: Closed knuckle front axles. [Re: NITROUSN] #1380163
02/03/13 05:52 PM
02/03/13 05:52 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yes if Its a d44 its open and has axle joints just drum breaks.
Re: Closed knuckle front axles. [Re: 76dodgeboy] #1380164
02/04/13 12:09 AM
02/04/13 12:09 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Incorrect. I had a closed knuckle Dana 44 with drum brakes. Was gonna try to convert it to disk, but just got a normal one instead.
But it did have u-joints.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Closed knuckle front axles. [Re: OhioMopar] #1380165
02/04/13 01:29 AM
02/04/13 01:29 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
72-74? I don't know much about pre 72
Re: Closed knuckle front axles. [Re: 76dodgeboy] #1380166
02/04/13 03:20 AM
02/04/13 03:20 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Duh. Missed that part. Sorry. I'm actually not sure what year it was. Most likely pre-'72.
1969 Dart GTS 340
2015 Dodge Dart GT
