Re: Go ahead and laugh, I'm lazy, Why not?
[Re: BDW]
#1379985
02/02/13 02:14 AM
02/02/13 02:14 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
[Re: A12]
#1379990
02/02/13 05:40 PM
02/02/13 05:40 PM
Posts: 141 Ohio, USA
Donny
Ohio, USA
Would you put it on a race car........if not then why on a street car?
Drain bolt = one (1) moving part. Proven pretty darn reliable, about a $1 or two at the most. A good running engine with oil in it, about $$$$$$.
How often do you change the oil to have to use a quick drain system?
What's next a "dry-break" system for the gas tank filler because a quarter turn cap takes too much time to open and close?
Not just that but really how messy is draining the oil during an oil change?
[Re: bigblock340power]
#1379992
02/03/13 03:19 AM
02/03/13 03:19 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
I think some of you are over thinking a simple task! At least the simple part. Now, if someone would come up with a better way to get at the oil filter......... I know, remote filter.
Better way to get the filter....BIG BLOCK....
[Re: That AMC Guy]
#1379993
02/03/13 11:31 AM
02/03/13 11:31 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I think the next logical step would be to make a drain valve that takes a hex or torx style bit to turn.
Granted, I've never really had people crawling under my cars trying to figure out what oil drain plug I had, but something with a little security makes sense.
I'll admit, I do get tired of having 5 cars all with different size drain plugs and not having the mental facilities to remember which car has what.
thats why i use a adjustable wrench.
[Re: dhkennedy]
#1379994
02/03/13 12:59 PM
02/03/13 12:59 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
Saw on YT that a Ford has that, no cap just shove the filler in the tube.
Many chrysler products have this as well.If you need to add fuel out of a normal can,in the trunk/cargo area is a special funnel that gets inserted first.The nozzle releases the locks. jeep,some trucks,charger, challenger,viper all have capless fuel system.
The oil drain valve could be useful.depends how far it hung down(clearance issues?) good advantage is It should save from stripped drain plugs.Some people are animals,some pans are just weak in that area.most do it you're self people are ok.I can speak from experience.The shop I worked at years ago had a contract with local quicky oil change shop.stripped drain plugs where a daily repair,couple oil pan jobs a week,and a couple engines a month.Had to drop them because couldn't keep up with our daily customers.I see the valve being useful if the quality is good and clearance isn't an issue
[Re: moretoys]
#1379995
02/03/13 01:43 PM
02/03/13 01:43 PM
Posts: 4,744 Florida
BDW
You guys have touched on all the reason I added the valve. - Having to crawl back under the car after not having the right size wrench the 1st time - Worrying about getting it cross-threaded and stripping the pan - It will definitely help me do the changes more often And my all-time favorite: No more hot / splashed oil on my hands or garage floor. The car needs to be on ramps or jack stands to change the oil. Now if you’re honest you’ll admit this has happened to you more than once: After contorting yourself under the car the drain plug snags on the last thread and you don’t jerk it away fast enough at the precise right angle and the hot oil splashes out as you drop it in the drain pan cursing. I understand it’s not for everyone, but no more headaches for me.
[Re: BDW]
#1379996
02/03/13 03:02 PM
02/03/13 03:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looks to me like a bunch of the naysayers failed to notice that there is a plug AFTER the valve.
Not a realistic chance of you losing your oil.
It's also simpler to control the oil when draining and much cleaner.
Any of you naysayers ever put a petcock in the block to drain coolant? I do, one on each side. Way easier to drain coolant as needed, which is much less often than an oil change.
Of course people who actually work on their cars would appreciate things like that, those who don't mock them.
#1379997
02/04/13 07:28 PM
02/04/13 07:28 PM
Posts: 168 Washington State, USA
Winchester 73
on the gm 80s "tech 4" four cyl,the drain plug was a 3" hand screw type setup in the bottom of the pan that held the oil filter on top of the big plug,,,,, so the drain plug WAS the oil filter!the filter was an open type element and had an o ring on top that screwed into the bottom of the pickup(you could see it if you looked up thru the bottom of the big hole in the pan)
so oil was filtered before it went into the pickup tube and the pump doesnt get to eat dirt.ive often pondered putting this typ of setup on a mopar.
[Re: Supercuda]
#1379998
02/04/13 07:57 PM
02/04/13 07:57 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
I'm pretty sure that 99.99% of the members on here have turned a wrench or two and removed an oil pan bolt at least once in their life..............just think it's funny to over complicate a simple task with more parts than necessary especially a car or truck older than 30 years old. What's next adding fuel injection because you might need to adjust the idle speed every so often and you have to go and get a screwdriver to do it?
And remember the subject title of the OP
"Go ahead and laugh, I'm lazy, Why not?"
I mean he did ask us to GO AHEAD AND LAUGH and then ask Why Not? So we've had a laugh or two and told him WHY NOT.
[Re: A12]
#1379999
02/04/13 09:44 PM
02/04/13 09:44 PM
BDW
So we've had a laugh or two and told him WHY NOT. Quote:
I haven't really heard a good reason for why not, other than you don't think it's "manly"
I'm not trying to convince anyone to change their drain plug, just happy it works for me.
[Re: BDW]
#1380001
02/04/13 10:50 PM
02/04/13 10:50 PM
A12
N.E. OHIO, USA
Is this the same FUMOTO valve?
[Re: A12]
#1380002
01/28/14 04:25 AM
01/28/14 04:25 AM
Posts: 350 Houston
it's Bob
Houston
Better question; Would you put it on your airplane?
Actually, quick drains like this are very common on airplanes. Usually of the push and twist style but this could work too.
