What are the downsides of body lifts? #1378978
01/31/13 12:27 AM
01/31/13 12:27 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I just recently got a 75 Dodge Power Wagon. It is a 440, 4 speed with the 203 t-case Full Time 4wd. It seems a bit taller than stock, but I don't know what a stock W200 should sit like.
I was given a 3 inch body lift kit which consists of several plastic spacers, steel hardware and some rudimentary instructions. The tires on the truck are weathercracked to the point where I'd never trust them on the road, so I'll be replacing them. I may run 35s.
I've never installed a body lift, so I am curious about the mods needed. I figure that the hard lines to the master cylinder have enough slack. The trans and t-case shifters will just sit lower. Is the steering column affected? Do you have to clearance the bottom of the fan shroud? What other mods are necessary? Thanks, Greg
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378979
01/31/13 12:56 AM
01/31/13 12:56 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Clutch linkage, borgsen steering shaft is best to do now and makes the lift easier ostensibly far as the steering issue. Id consider dropping.g the radiator. Even with 3" the tires will most likely rub in front. If you plan to go wheeling off road they WILL rub. Post pics of the truck. What size tires are on it now. How many front leafs. Keep in mind the 4was ALL had a block in the rear so don't mistake that for a lift. If you don't want to drop the radiator Id consider an electric fan. Than yoyd have to lengthen the hoses. Also fuel filler extension
Re: What are the downsides of body lifts? [Re: 76dodgeboy] #1378980
01/31/13 01:22 AM
01/31/13 01:22 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The tires on it now are pretty short, something like 31 1/2" or so. 35s are just an idea, I'll likely run what I can find 33"-35" at a reasonable price used. This truck is replacing my 74 Camper 9000 2wd that I use for misc hauling jobs. I also need a truck to push project cars around the yard. I will be doing some off-road fun, but nothing hardcore. A decent 33" tire may negate the use of any body lift anyway.
I didn't think about the fuel filler!
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378981
01/31/13 02:55 AM
01/31/13 02:55 AM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
I did a Skyjacker 3" body lift on a 84 Toyota and did a little off roading in Florida. Even though it was nearly flat and in sand it stressed the cab mounts so bad that I pulled it after a year. When I descided on lifting my 79 RC salvaged springs and repacked the front and flipped the rear hanger and ended up with a 5" lift with 33.5s.
Re: What are the downsides of body lifts? [Re: dhkennedy] #1378982
01/31/13 10:44 AM
01/31/13 10:44 AM
scratchnfotraction Offline
IMHO, leave it on stock mounts and do a spring lift with steer gear mods/upgrades.
I had 3" lifts on a few,always shifting troubles, mounts come loose when off roading,ect...
I like a 6" lift with 17/40/15 ground hawgs,I used a droped pitman arm,raised steering arm,adjustable dog bone. swamper 39.5 are nice. best all around was the 14/35/15 hawgs with the 6" lift.
I used 12" springs in the rear to ditch the stock block with the lift block in the lift kit.
you could do a 4" front spring with the shackle flip in the rear for a cheap lift to fit 35s
body lifts are like open diffs,they work but not like you need them to.
Re: What are the downsides of body lifts? [Re: scratchnfotraction] #1378983
01/31/13 09:40 PM
01/31/13 09:40 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Maybe this body lift kit is worth what I paid for it.
A guy GAVE it to me.
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378984
01/31/13 10:07 PM
01/31/13 10:07 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Im planning to put a 3" body lift object my wife clubcab and 4" suspension. I can't afford all the crap skyjacker and super lift DON'T include in their "kits". Heck I can't afford their kits either. So far I have $100 in the body lift $200 for the 4" rear springs and $0 in the fronts because they were object a trailduster and I made money on it. It'll most likely never get beat like mine will. It'll be more of a Pavement pounded. Also plan for a 518 swap with an ultra bell to hook to the 400
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378985
01/31/13 10:31 PM
01/31/13 10:31 PM
yep,for sure I would use the springs with no body lift on that brute.
some 12" wide 4.5 bs rims,17/40s,6" lift with the nose slightly up,440 granny trany full time with 4.56/locker in the rear.
I would be putting a part time kit in the xfer with a set of happy hookers for 2x scratchin with just the 4.56 spining the locker in low range 3rd gear
have you invested in a 5 gallon pail pump yet??
comes in handy with 2 axles and granny tranny/exfer. dont you have 2 4x4s now? remember,the lowest bolt on front output shaft rear cover drians ALL of the xfer lube when you service it.
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378986
02/01/13 07:44 AM
02/01/13 07:44 AM
Ca
76440 Offline
76440  Offline
Ca
Did the guy ad the ramcharger macho tape stripe to the gate? Or is originally off a 77-78 orange macho ramcharger?
Avoid a bodylift esp. on a 4psd truck.
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378987
02/01/13 08:53 AM
02/01/13 08:53 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Still not worth it.
Body lifts are garbage. I've had lifted 4x4s for 20 years, vehicles that saw lots of street duty as well as some pretty hardcore trail action, and I wouldn't use a body lift if it was free. If you want to lift it, a suspension lift is the only way to go.
Earning every penny of that moderator paycheck.
DBAP
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378988
02/01/13 09:27 AM
02/01/13 09:27 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Body lifts for the most part = JUNK
Re: What are the downsides of body lifts? [Re: NITROUSN] #1378989
02/01/13 04:21 PM
02/01/13 04:21 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've seen people use drilled out hockey pucks for body lifts I always thought body lifts looked bad because of the bumper gap and so on.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: What are the downsides of body lifts? [Re: Silver70] #1378990
02/01/13 04:53 PM
02/01/13 04:53 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Too high a body lift can stress the cab mounts and crack the sheet metal. I think a 1" body lift is OK, but I wouldn't go anymore than that.
This pic is of a Toyota, but I've see the Dodges crack around the rear cab mounts from 3"+ lifts before.
Re: What are the downsides of body lifts? [Re: 440newport] #1378991
02/01/13 04:58 PM
02/01/13 04:58 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I've only seen 2-3" available. Id rather run 2". I can always reinforce the area too.
Re: What are the downsides of body lifts? [Re: Silver70] #1378992
02/01/13 06:34 PM
02/01/13 06:34 PM
That, too. They look awful.
DBAP
Re: What are the downsides of body lifts? [Re: 76440] #1378993
02/02/13 12:07 AM
02/02/13 12:07 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Bob added that stripe. I like it, but it will get removed when I repaint the truck this summer.
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378994
02/02/13 07:33 PM
02/02/13 07:33 PM
north carolina usa
beeson44 Offline
beeson44  Offline
north carolina usa
at my body shop I have seen many trucks not hit hard at all kill the body mounts to the point of no repair with 3 inch body lifts, I think it lets the cab move around more and in a wreck it gets a running start at the cab mounts and twist them.
Re: What are the downsides of body lifts? [Re: beeson44] #1378995
02/02/13 11:36 PM
02/02/13 11:36 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Anyone want to buy a body lift, cheap ?
Re: What are the downsides of body lifts? [Re: Kern Dog] #1378996
02/03/13 12:39 AM
02/03/13 12:39 AM
find a chebby guy with a 4x4 and GIVE them to HIM saying it does not work on your mopar. it was listed as going on a chebby.
after handing it to him...RUN!
