Re: Is a 360 manufactured in 1971 more desirable?
[Re: rjones]
#137841
10/16/08 10:46 PM
10/16/08 10:46 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Yes,it is true that the block is cast differently than later ones and do have thicker walls. Desirable? Well it depends on who you ask. If you plan on making a monster 406 C.I. stroker small block (4" crank,massive bore job & oversized pistons,Eddy heads) yes the 71 72 360's tend to hold up better in racing conditions. As a core ,the value is no different than any other 360 block,IMO. Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#137842
10/16/08 11:03 PM
10/16/08 11:03 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
Our resident smallblock guru, as well as several others, have debunked this myth many times. No block cn be assumed better than another based on production/casting date until it is sonic checked. I went through several block before finding a good specimen for my 408. ![](/ubbthreads/images/graemlins/Twocents.gif)
Also, one does not need to ovebore more than they would on any other (ie stock stroke) rebuild with a 4" stroke crank, hence the nomenclature "stroker motor"... ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: 451Mopar]
#137846
10/16/08 11:32 PM
10/16/08 11:32 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Got pics? In what year did this change?
[Re: rjones]
#137853
10/17/08 01:39 PM
10/17/08 01:39 PM
Posts: 169 arizona
VPrace
arizona
I have heard they are due to thicker cylinder walls. Any truth in this?
Thanks,
Roger
wasn't the original story that early 360 blocks were cast with the 340 molds and therefore were only bored to 4 ? that was supposed to be why the walls were thicker?
[Re: goldmember]
#137854
10/17/08 01:45 PM
10/17/08 01:45 PM
quick77rt
Parts Problem
Parts Problem
So each year gets thinner? Yes they do, my friends 2006 was running bad, pulled a head and BAM it was so new of a block there were only pistons and anti-freeze, no sign of cylinder walls. Now we dont know what to do? ![](/ubbthreads/images/graemlins/musik010.gif) Sorry...had to. Quote:
[Re: VPrace]
#137855
10/17/08 01:48 PM
10/17/08 01:48 PM
Posts: 4,463 Michigan
MarkZ
Worthy
Worthy
Differences in early vs later 360 are probably so minute it's not even worth the headache of trying to find one. The only real desirable LA 360 blocks were built from 89'-91'. They had provisions for roller cam shafts. If you're not concerned about that, just find one and build it.
[Re: VPrace]
#137856
10/17/08 02:53 PM
10/17/08 02:53 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
That's what I heard also. That these were desireable, because they could be bored out, and made into a 340 if need be. IIRC you could even by some sort of spacers for the main bearings to work (use the 340/318 crank)
That was pre stroker fad days of course. These days, use a 4.0 crank and go nuts ![](/ubbthreads/images/graemlins/musik010.gif)
