Re: Budget 360
[Re: 71Polara383]
#1378051
01/29/13 08:08 AM
01/29/13 08:08 AM
Posts: 653 Fort Worth, TX
Dago Red
Fort Worth, TX
It's doable. I got low 12's from a pump gas .030 over 360, stock J heads and a hyd cam. It had a stock bottom (had it balanced) 750 Holley, Strip Dominator, MSD ignition, 1 5/8 headers w/mufflers in a 3100# F-body. 999 T-Flite with a T/A manual valve body and a Dynamic 3500 converter. 9" slicks 26" tall through a 8 3/4, spool 4.56's S/S springs/snubber.
If You Can't Be Good, At Least Be Colorful
Re: Budget 360
[Re: 71Polara383]
#1378052
01/29/13 01:16 PM
01/29/13 01:16 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
My idea of "stock bottom end" is NOT replacing pistons, rods, etc. - taking a production short block and installing a cam, heads, intake, etc. Given that, the compression ratio of the stock pistons would be the limiting factor. IMO your best bet would be putting a mild (hydraulic roller) cam, ported/decked heads, headers, and a carb intake on a 360 Magnum short block. OK, you also mention NOS - by the time you buy the kit you could have bought decent pistons, and not have to keep buying NOS refills. Best bang for the buck? 360 Magnum longblock (preferred 100K or less), better cam and valvesprings, carb and intake, headers, and a 125 shot.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: Budget 360
[Re: Evil Spirit]
#1378053
01/29/13 01:44 PM
01/29/13 01:44 PM
Guitar Jones
I've been 10.16 with an MP 360 shortblock, stock crank, rods and hyper pistons. Raced it for 15 years, it's still together. I pulled it when I built the 408 shortblock with a lot of good parts, it lasted for 12 passes. Power is all in the heads, induction and cam. I may just freshen it and put it back together.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Budget 360
[Re: Guitar Jones]
#1378054
01/29/13 02:09 PM
01/29/13 02:09 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
You will need to watch you valve to piston clearance with a truly stock bottom end. I doubt a Hughes 6368 would clear without valve reliefs. It might,but it will be close. Also the heads will need work to get that much lift before the retainer/ valve guide clearance becomes an issue. 400 hp naturally aspirated is do able. 450 is going to be hard to do because of the above. Getting the cam right for the rpm range you will run it in,and decent heads are the important factors for a low compression deal to work. You would be better off trying to optimize midrange torque than going for high rpm power with a stock short block. Keith
Re: Budget 360
[Re: Dunnuck Racing]
#1378055
01/29/13 03:53 PM
01/29/13 03:53 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd do stock bottom end, thin mP head gaskets, magnum heads w/stock rockers (that combo should yield @9:1 compression) with hughes #1110 springs and 2.2L retainers, comp cams 270H, RPM air gap, and headers. you'll probably want a 2500RPM converter should get you into the mid 13's easily...I'd wager it'd be close to the old 380HP crate motor power wise
