fuel sending unit float ? #1377954
01/28/13 10:56 PM
01/28/13 10:56 PM
S.E. WI
allmopar Offline OP
allmopar  Offline OP
S.E. WI
I just removed my fuel sending unit from my tank to replace the pickup sock. While I had it out I noticed the brass float is about 1/3 full of fluid. I always thought the float should be dry inside. The wierd thing is I cannot see any bad spot on the float where the fuel would have entered and the gas guage seemed to work fine. It is a 3/8 sending unit from a 71 B body. Is there anyone who sells just replacement floats ? Is it the same brass float that is used on the 5/15 sending unit ?
Re: fuel sending unit float ? [Re: allmopar] #1377955
01/28/13 11:01 PM
01/28/13 11:01 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I've fixed dozens of brass floats. Hold the float in your hand, blow compressed air over it, you will locate the hole, keep blowing until no more gas escapes, keep track of the hole and then solder it...use a minimum of solder so the weight isn't changed too much...then you can tell your story to your grandkids.
Re: fuel sending unit float ? [Re: MO_PA] #1377956
01/28/13 11:45 PM
01/28/13 11:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ford dealer will have a new one to replace the Mopar piece. Use the google search at the top of this page for past discussions of this question.
Re: fuel sending unit float ? [Re: stumpy] #1377957
01/29/13 08:04 AM
01/29/13 08:04 AM
BDW Offline
BDW  Offline
Re: fuel sending unit float ? [Re: BDW] #1377958
01/29/13 09:59 AM
01/29/13 09:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree Ford has them.I saved probally 4 or 5 from Vans that I had to replace pumps in.Lots better than the brass ones.Rocky
Chrysler Firepower
