Did my timing chain jump ? #1377527
01/28/13 12:43 PM
01/28/13 12:43 PM
NEW YORK
MAXEDWEDGE Offline OP
NEW YORK
The motors(440) been together for four yrs. now .i started it up and went for a ride when i got home i shut it down and when i re-started it ,it started and stalled . to make a short story endless i ended up moving the dist. about 90* to get it to start back up,it ran like *#%# . I checked TDC with the piston and balancer it looked good .also checked the dist. drive gear the keyway looked good so did the angle of the slot . any thoughts would be appriciated .
Re: Did my timing chain jump ? [Re: MAXEDWEDGE] #1377528
01/28/13 01:03 PM
01/28/13 01:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It could have but you checked TDC and the dist was
in the right spot(before you moved it)... I did have
a old engine in my truck jump time and it ended up
right back to where it should be(weird) but every
valve was bent... I checked the compression and it
was like 40psi.... do a compression check
Re: Did my timing chain jump ? [Re: MR_P_BODY] #1377529
01/28/13 01:29 PM
01/28/13 01:29 PM
NEW YORK
NEW YORK
you know what the rotor was about one terminal off
Re: Did my timing chain jump ? [Re: MAXEDWEDGE] #1377530
01/28/13 02:16 PM
01/28/13 02:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In that case you most likely jumped... turn the crank
back and forth and see when the rotor starts to turn
Re: Did my timing chain jump ? [Re: MR_P_BODY] #1377531
01/28/13 03:10 PM
01/28/13 03:10 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Make sure the distributor didn't move or the plate or other internal parts arn't screwed up before you start tearing the engine front apart.What ignition box are you running?
Re: Did my timing chain jump ? [Re: MAXEDWEDGE] #1377532
01/28/13 03:18 PM
01/28/13 03:18 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
What type of dist./oil pump drive gear are you using? I've seen the gear slip on the shaft of the non-heavy duty gear drives. The heavy duty ones have the pin thru the gear and shaft. Just food for thought.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Did my timing chain jump ? [Re: B G Racing] #1377533
01/29/13 07:17 AM
01/29/13 07:17 AM
NEW YORK
NEW YORK
checked the dist internals ,i'm running an MSD 7 and the gear drive has the pin in it .i did pull it and check it . Thanks
Re: Did my timing chain jump ? [Re: MAXEDWEDGE] #1377534
01/29/13 10:16 AM
01/29/13 10:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 440 did something similar.It was new and running fine.went to start it a day later.Popping and wouldnt run.Pulled the cap and dist rotor was off.I said some nice words thinking I would be tearing apart a new engine.Pulled the dist and it had come apart inside.That was a Mallory unit.Installed a new MSD full setup and never looked back.Rocky
Chrysler Firepower
Re: Did my timing chain jump ? [Re: therocks] #1377535
01/30/13 09:13 AM
01/30/13 09:13 AM
NEW YORK
NEW YORK
I pulled the timing chain cover off last night , the chain is sloppy but the dots line up and the hex-adjust is still tight ??????. It almost seems as if the dist. gear moved .I checked it again the pins not broken.
