Help!! Trunk spring rods about killed me. #1377416
01/27/13 11:54 PM
01/27/13 11:54 PM
Charleston, SC
safaritow Offline OP
Charleston, SC
So I crawled into my trunk to see how I might be able to make my trunk lid stay up when I open it (1970 RoadRunner) So it looked like three slots and all I had to do was move it over one to make it tighter.... Well Im lucky I have a face left after it came apart with me inside with it. So any one have some ideas on how to put them back with out killing me? Diagrams or pics would be great. Thanks for your help.
Re: Help!! Trunk spring rods about killed me. [Re: safaritow] #1377417
01/28/13 02:11 AM
01/28/13 02:11 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Hard to believe that much violent energy can be stored in such an innocent looking package.
Another one is the clock spring on a power window regulator. My arm still aches just thinking about it.
I can't help you other than to suggest the FSM. Follow the instructions EXACTLY and wear a cup, hardhat and safety glasses.
Kevin
Re: Help!! Trunk spring rods about killed me. [Re: safaritow] #1377418
01/28/13 02:27 AM
01/28/13 02:27 AM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
I can't remember where I saw it, but I read that you can use a ratchet strap to draw the ends of the trunk lid torsion bars together to remove them and make your adjustment. You'll need to prop the trunk lid open to relieve tension on the bars. I need to do this to mine too since I added a wing to mine.
Re: Help!! Trunk spring rods about killed me. [Re: safaritow] #1377419
01/28/13 12:59 PM
01/28/13 12:59 PM
USA
Hooligan Offline
Hooligan  Offline
USA
I took a piece 3/4" plywood, and cut it approximately 13'' X 3.5"...then cut a slot 3.5" X 1/2" in one end to make a lever to twist the trunk spring into place. I also screwed a small strap of steel across the 1/2" slot to keep the wood from splitting apart. You still have to pry the end of the spring with a screw driver or similar tool until you line up the spring with your desired slot position. My camera is dead...otherwise I would have sent you a pic.
Re: Help!! Trunk spring rods about killed me. [Re: Hooligan] #1377420
01/28/13 01:35 PM
01/28/13 01:35 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Been there, done that! Boy was I in for a surprise how much tension was on those things. Got them back in but it was so long ago I forgot how I did it.
Re: Help!! Trunk spring rods about killed me. [Re: Hooligan] #1377421
01/28/13 01:44 PM
01/28/13 01:44 PM
Andrewh Offline
Andrewh  Offline
a person on the coronet registry board, made a metal piece that held the s shape portion in a bracket.
you could then use a ratchet to twist it into place.
seemed like a really good idea.
the board reset recently, but maybe you could post and ask them to post it again.
Re: Help!! Trunk spring rods about killed me. [Re: safaritow] #1377422
01/28/13 08:52 PM
01/28/13 08:52 PM
Charleston, SC
Charleston, SC
Ok guys, Thanks for the help Ill try the wood thing and see if it works. Im a little gun shy but ill armor up befor I go in... Thanks again
Jeff
Re: Help!! Trunk spring rods about killed me. [Re: safaritow] #1377423
01/28/13 09:01 PM
01/28/13 09:01 PM
GA
roadrunninMark Offline
GA
I need to do this as well.
Re: Help!! Trunk spring rods about killed me. [Re: safaritow] #1377424
01/28/13 09:51 PM
01/28/13 09:51 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Jeff
Borrow someone's full face street bike helmet...
Re: Help!! Trunk spring rods about killed me. [Re: A12] #1377425
01/28/13 09:54 PM
01/28/13 09:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I thought about using one of my ratchet m/c tie-downs to pull them out as mention above.....and I thought about using a couple of all-thread rods and a turnbuckle as it would be much more progressive loosening to get them back in the desired location.
Re: Help!! Trunk spring rods about killed me. [Re: safaritow] #1377426
01/29/13 05:02 AM
01/29/13 05:02 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Re: Help!! Trunk spring rods about killed me. [Re: roadrunninMark] #1377427
01/29/13 04:15 PM
01/29/13 04:15 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Re: Help!! Trunk spring rods about killed me. [Re: MoparMarq] #1377428
01/29/13 06:53 PM
01/29/13 06:53 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
You can put a pipe over a vice grip
