T.A. chally- torque converter hub won't fit in crank #1376385
01/26/13 04:03 PM
01/26/13 04:03 PM
junction city oregon
V
viperblue72 Offline OP
V
HI all. I just went over to help a friend on a t.a. challenger. The converter hub is too big for the crank.
So my question is, does a 4 speed crank not allow for an automatic? I've never had this problem.
Also what would be the best solution?
Re: T.A. chally- torque converter hub won't fit in crank [Re: viperblue72] #1376386
01/26/13 04:06 PM
01/26/13 04:06 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Get a different converter.
Re: T.A. chally- torque converter hub won't fit in crank [Re: moparpollack] #1376387
01/26/13 04:09 PM
01/26/13 04:09 PM
V
V
Okay I am guessing this thing has a early 318 crank or something? What torque converter would work?
The crankshaft hub is not machined out except for the pilot hole. The big hole the converter usually slides into in really crude and smaller than normal. Is there a way to make this work simply?
Re: T.A. chally- torque converter hub won't fit in crank [Re: viperblue72] #1376388
01/26/13 04:41 PM
01/26/13 04:41 PM
NW/Indiana - Chi town
ricomondo Offline
ricomondo  Offline
Is the oilite bushing from the 4spd still in the crank?
The crank is the same for the 4 spd and auto on the T/A block.
On a 4 spd car, there's a pilot bushing, and inside the pilot bushing is a small copper/brass bushing. The pilot bushing along with the oilite bushing have to come out of the 4spd crank for an auto input shaft to fit.
Re: T.A. chally- torque converter hub won't fit in crank [Re: ricomondo] #1376389
01/26/13 04:42 PM
01/26/13 04:42 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
Had that same trouble with 273 crank
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: T.A. chally- torque converter hub won't fit in crank [Re: WINGCARS_6970] #1376390
01/26/13 04:54 PM
01/26/13 04:54 PM
ricomondo Offline
ricomondo  Offline
Here's the pilot bushing
and oilite bushing together. The oilite bushing is the one in the center of the pilot bushing.
These have to come out of a 4spd crank to get an auto trans to mate properly.
GY3 71 Demon 340
Re: T.A. chally- torque converter hub won't fit in crank [Re: ricomondo] #1376391
01/26/13 04:55 PM
01/26/13 04:55 PM
V
V
NO bushing is still in the crank. It just has a pilot hole. The crank is not original I don't believe. It is a t.a. block but the crank isn't the same as all the 340 cranks I have(hole for converter hub is much smaller). So my only guess is that it is a 273/318 crank out of an earlier block?
Re: T.A. chally- torque converter hub won't fit in crank [Re: viperblue72] #1376392
01/26/13 04:58 PM
01/26/13 04:58 PM
V
V
Ray, what I meant by machined out, I mean that the part the hub slides into isn't a smooth surface as if it wasn't machined for an automatic. Definitely not a iolite bushing inside or anything like that.
Re: T.A. chally- torque converter hub won't fit in crank [Re: viperblue72] #1376393
01/26/13 06:57 PM
01/26/13 06:57 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Some 273 have a smaller converter nub, this bit me on the ass 20 years ago when I was doing a motor in a Duster.
Re: T.A. chally- torque converter hub won't fit in crank [Re: gdonovan] #1376394
01/26/13 07:05 PM
01/26/13 07:05 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
a pic would help
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: T.A. chally- torque converter hub won't fit in crank [Re: viperblue72] #1376395
01/26/13 07:17 PM
01/26/13 07:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Measure the bore of the converter hub register in the end of the crank, it should measure 1.810"....if it measures 1.550" it is a 273 crank. If it does measure 1.810" them measure the hub on the converter, it might be oversized.
In some rare cases a standard trans crank won't have the register bored at all.
Re: T.A. chally- torque converter hub won't fit in crank [Re: John_Kunkel] #1376396
01/26/13 07:40 PM
01/26/13 07:40 PM
V
V
The crank hole is definitely without doubt smaller. My other 340 cranks are very noticeably bigger and machined better. We've tried a few different converters. I can not get a pic since the car is at my friends house 10 miles from here.
I am sure this is a older style crankshaft with smaller hole. Now it's just a matter of what the best solution is. Machine the crank, or find a converter? Although the early 727 is different
Thank you guys for input.
Re: T.A. chally- torque converter hub won't fit in crank [Re: viperblue72] #1376397
01/26/13 09:25 PM
01/26/13 09:25 PM
NY
aarmaniac Offline
aarmaniac  Offline
NY
I had the same problem when building a street motor for my AAR. Solution was pulling the motor apart and machining the crank to fit the hub on the converter. Some mentioned using a grinder to do it in the car but I did not think that was the best idea.
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
Re: T.A. chally- torque converter hub won't fit in crank [Re: aarmaniac] #1376398
01/26/13 09:56 PM
01/26/13 09:56 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Is a converter available for the smaller crank hub? Pulling the engine, then the crank for replacement or hub machining is a lot of work and dollars . A new converter would be cheaper.
Re: T.A. chally- torque converter hub won't fit in crank [Re: aarmaniac] #1376399
01/26/13 11:05 PM
01/26/13 11:05 PM
V
V
This is what I was afraid of. It will be a lot of work, but worse things happen. Thanks guys.
Re: T.A. chally- torque converter hub won't fit in crank [Re: viperblue72] #1376400
01/26/13 11:14 PM
01/26/13 11:14 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Ran into the same problem on my 340. All I had to do was get some emory cloth and rub the nob down a little until it fit maybe a thousand off. Give it shot it worked for me.
Re: T.A. chally- torque converter hub won't fit in crank [Re: magiccuda] #1376401
01/26/13 11:55 PM
01/26/13 11:55 PM
NY
aarmaniac Offline
aarmaniac  Offline
NY
If I remember correctly the difference was around .250 or so. It was a major setback, not one I will overlook again.
Re: T.A. chally- torque converter hub won't fit in crank [Re: rowin4] #1376402
01/27/13 12:01 AM
01/27/13 12:01 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
No, the input shaft is smaller too.
Re: T.A. chally- torque converter hub won't fit in crank [Re: gdonovan] #1376403
01/27/13 10:06 AM
01/27/13 10:06 AM
Silver Springs, Florida
Charrlie_S Offline
Charrlie_S  Offline
The hole in the crank changed sizes between 1967 and 1968. If I remember correctly the 273 and 318LA cranks will work in the 340 if rebalanced, but if 67 or earlier will have the small pilot hole. If this is a 904 trans (don't know about the 727), then yes, you can get a custom converter, with the small pilot and the large (68 up)splines inside. I have three converters, that were made that way.
Charrlie_S
66 Cuda 170 nitrous
66 Valiant 225 nitrous
65 Valiant 170 turbo
64 Valiant driver
64 Valiant roller
