Re: 100 amp alternator
[Re: Plymouth340]
#1375873
01/26/13 11:40 AM
01/26/13 11:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The Denso alt works great(3 wire units) has real good low rpm out put... 1 run a 85A Denso on both my race car and street rod... plus I like the external reg... why trash a alt if the reg goes bad... plus you can get a high out put reg... I just used the Chrysler production ones... based on where you tap your sense wire you can get different battery voltage... I get 14.9 at the battery on my street rod ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Quicksilver440]
#1375877
01/27/13 10:06 AM
01/27/13 10:06 AM
Posts: 89 Cleveland, Ohio
BB73Challenger
Cleveland, Ohio
I've been running a powermaster 140 amp for over 6 years. It's a one wire and I have had no issues at all, It came with an actual test sheet too that showed it put out over 80 amps at idle too. I did have to grind a little on my stock bracket to make it fit though.
I too run a high amp powermaster for fans, aftermarket ign, as well as being able to add on more electronics in the future. At idle with the fans on, Serious radio going, lights on and GPS plugged in It doesn't skip a beat. I've been running it trouble free for many years now.
[Re: Plymouth340]
#1375878
01/27/13 01:25 PM
01/27/13 01:25 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use a Tuff Stuff 100 amp alt with a #4 wire to the cut off switch.Works GREAT. The one I use is the one wire with the generic Ford/GM case.
[Re: 80arrow]
#1375880
01/27/13 04:43 PM
01/27/13 04:43 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
I had used one off a mid 90's pickup with a v-6. Just change the pulley over to a v-groove, was 90-100 amps
thats what i should do. can i still use my mopar constant output regulator with the mid 90's alternator? wired the same?
[Re: Just-a-dart]
#1375882
01/27/13 07:02 PM
01/27/13 07:02 PM
Plymouth340
CEDAR RAPIDS
That is what I'm doing the earlier ones have a V-belt and field connections that are bolt on later ones have serp. belts and goofy plugs for the field wires. Also the pulleys are the same as the small Delco (.665? if I remember right)
This is a old pic before I went back to v-belts (after this pic I put a vac pump on it) With the smaller alt pulley it was 2.25 to 1 ratio charged great at idle, but the sudden acceleration coming off the 2 step (3600leave 5500 flash)killed one after a while. Now using a 1.7 ratio and it's happy. Hope this helps
what size alt and crank pulley are you running now? i trans brake my car to 5000 and dont want to be losing belts..thanks
[Re: 80arrow]
#1375883
01/27/13 07:15 PM
01/27/13 07:15 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
How was the output down low like at idle? I need to upgrade, bottle heater hits the factory replacement one hard. Thanks
[Re: SpareParts]
#1375884
01/27/13 10:02 PM
01/27/13 10:02 PM
Posts: 814 in front of the computer
80arrow
Mine seemed to charge at 1000-1200 rpm I think. I don't have the car any more so I can't tell you the pulley size. I ran water pump, fan, magna fuel fuel pump, MSD 7al2. I'd run the fan and water pump after each pass to cool it down and never put the battery charger on in two years. This was with the altenator off the 90's dodge pick-up
[Re: Just-a-dart]
#1375886
01/27/13 11:39 PM
01/27/13 11:39 PM
Plymouth340
CEDAR RAPIDS
Sorry just looked at my notes 1.7 was my target ratio. Current pulleys 4.5 crank/2.5 alt 1.8 ratio. alt pulley is a little small, but I have had no trouble.
Around a 5"crank/3"alt (1.67 ratio) would be a good place to start.
sounds good i have a 5 inch crank pulley now will get a new 90 amp alt with 3 inch pulley,,thanks
[Re: Plymouth340]
#1375887
01/29/13 01:25 AM
01/29/13 01:25 AM
Posts: 7,664 IN
ahy
IN
"rule of thumb" alternators redline at 16,000 to 18,000 RPM. You probably want to be at around this RPM at engine redline to keep idle output adequate. It depends a lot on the engine setup but 1.67 ratio sounds a bit low. A bigger crank pulley or smaller alternator pulley may be in order.
