Re: TRUE HOOD SCOOP TESTS........................... [Re: 493_DART] #1375790
01/27/13 12:22 AM
01/27/13 12:22 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I'll be watching this for updates as i also need a different hood because my carb sits at the top of my scoop
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: TRUE HOOD SCOOP TESTS........................... [Re: 67mprfan] #1375791
01/27/13 01:32 AM
01/27/13 01:32 AM
State of confusion
Thumperdart Offline OP
State of confusion
Ya that looks tight under there for sure and although it looks like I might have just a bit more clearance than you I still want a taller filter than the 14x3 I run now.
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375792
01/28/13 12:05 AM
01/28/13 12:05 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
There is an article out there, maybe 6 years old, that says Warren Johnson figured it cost him 80HP to run the Pro Stock hood scoop.
Re: TRUE HOOD SCOOP TESTS........................... [Re: A/MP] #1375793
01/28/13 12:07 AM
01/28/13 12:07 AM
State of confusion
State of confusion
We`re listning...........what scoop cost em the loss and what did the best? Thankxxx........
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375794
01/28/13 12:26 AM
01/28/13 12:26 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
1 thing i'm looking into is removing my fuel regulator plate from under the carb that will give me aleast a 1/8 in more room....Good luck on your goal
Re: TRUE HOOD SCOOP TESTS........................... [Re: 67mprfan] #1375795
01/28/13 01:32 AM
01/28/13 01:32 AM
State of confusion
State of confusion
Guess it can`t hurt.............like me, you need a taller scoop.
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375796
01/28/13 03:41 AM
01/28/13 03:41 AM
does your scoop get taller in hieght above 130 MPH like my SS hemi scoop does?
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375797
01/29/13 04:31 AM
01/29/13 04:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Ya I remember about Rebel`s deal and really would like about a 6" 6-pac scoop but havn`t really looked yet........
dude, i'm a total convert over the cowl deal for more mph & lower e.t but i've also found another improvement with a cowl since then. you might not race in the rain but i sure do tow home in the stuff. a cowl keeps my air filter looking clean as new since the road grime isn't being mixed with the rain going thru a 6 pak. keeps the motor dryer too.
Re: TRUE HOOD SCOOP TESTS........................... [Re: Cab_Burge] #1375798
01/29/13 11:53 PM
01/29/13 11:53 PM
State of confusion
State of confusion
My scoop is trying to rip itself off of the hood on every pass and even at 70 on the fwy that`s why I feel it`s grabbing air just not enuff........... So Rebel,how do remove the hood by yourself w/out something to grab on to cos I rely on me only w/that stuff.
Re: TRUE HOOD SCOOP TESTS........................... [Re: 493_DART] #1375799
01/30/13 12:43 AM
01/30/13 12:43 AM
State of confusion
State of confusion
heres mine Dom ----------
This is one of my choices but only if they`re no taller than maybe 8"`s...........
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375800
01/30/13 05:01 AM
01/30/13 05:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
well you goinna have to make a friend coz there's no way i can remove the front clip by myself. my mum n law/wife/daughter or mate help me. maybe if i hadn't removed the grill i could have a handgrip but i was thinking aero when i modified mine, there's nothing to grip but lite enough to lift. i went cowl because of that reason you mentioned, i made my 6 pak taller & it tried to destroy the mounting points for the front clip. remember, mines made of bagged Kevlar, the whole thing weighs about the same as just a glass hood. if you made just a hood n cowl from carbon you could probably manage by yourself, just beware in windy conditions. i'm working on a carbon trunk & wing. just the trunk skin could be used as a kite.
Re: TRUE HOOD SCOOP TESTS........................... [Re: rebel] #1375801
01/30/13 12:43 PM
01/30/13 12:43 PM
State of confusion
State of confusion
Now I see that you have a removeable ft. clip so definately a two person deal there. So I wonder if I could hole saw a couple of holes in the middle of the cowl to lift it easier but not affect the inner workings of the scoop.............
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375802
01/30/13 03:11 PM
01/30/13 03:11 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
After reading until I was numb, I settled in on the aero scoop. It seems the keys factors as has already been spoken is getting it in clean air and getting it sealed. I'll post a couple of pictures that shows a little of what I did.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: TRUE HOOD SCOOP TESTS........................... [Re: clovis] #1375803
01/30/13 03:12 PM
01/30/13 03:12 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Sealing
'75 Plymouth Duster
Re: TRUE HOOD SCOOP TESTS........................... [Re: clovis] #1375804
01/30/13 03:14 PM
01/30/13 03:14 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
The hard part was getting something I could lift up the hood with and when closed would seal up. It is amazing what you can do with a 99 cent pie plate.
'75 Plymouth Duster
Re: TRUE HOOD SCOOP TESTS........................... [Re: clovis] #1375805
01/30/13 03:14 PM
01/30/13 03:14 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Last one
When the hood is close the air bell rides down inside the pie plate to form the seal. I did put some foam around the pie plate to ensure it was making a good seal. I beleive the air bell helps also as it makes for a good transition into the carb.
Re: TRUE HOOD SCOOP TESTS........................... [Re: clovis] #1375806
01/30/13 04:41 PM
01/30/13 04:41 PM
State of confusion
State of confusion
That looks doable how tall is that scoop?
Re: TRUE HOOD SCOOP TESTS........................... [Re: Thumperdart] #1375807
01/30/13 05:38 PM
01/30/13 05:38 PM
fresno ca
mikeysmopars Offline
fresno ca
I have a scoop like that if you want Dom, pm me.
Founder and CEO of the Central Valley Mopar Drag Pack
