Dodge Truck Fuel Sending Units 1973-1979 #1375673
01/25/13 10:42 PM
01/25/13 10:42 PM
Annapolis Maryland/WV
dmnrr04 Offline OP
dmnrr04  Offline OP
Does anyone know where to get replacement fuel tank sending units for Dodge trucks from 1973-1979 ? How about fuel tanks as well ?
Thanks,
Rick
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: dmnrr04] #1375674
01/25/13 11:25 PM
01/25/13 11:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Junkyard.
Apparently the sending unit can be rebuilt. Depending on what's wrong with the tank it can be fixed
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: 76dodgeboy] #1375675
01/26/13 12:21 AM
01/26/13 12:21 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
You might find a sending unit at a dealer if your VERY lucky.
They have been NS1 for several years, but if your dealer will do a nation wide search you may find one.
Also you may find one on eBay, they turn up from time to time. But you will pay dearly for it.
If you cant rebuild yours, or if its not just a bad ground (common problem) as a last resort you can add an aftermarket one to the tank, but it will require you to use a hole saw, and add a hole to the top of the tank. Be sure to order the ford/mopar style to get the closest to correct ohms for the factory gauge. 73-10 ohm.
http://www.tanksinc.com/index.cfm/page/ptype=product/product_id=276/mode=prod/prd276.htm
http://www.amazon.com/Jaz-Products-378-2...ASIN=B002RLCOD6
For the tank, either a salvage yard, or local sale.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: dmnrr04] #1375676
01/26/13 06:10 AM
01/26/13 06:10 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Thanks,
Rick
In the cab, or in the frame tank?
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: dmnrr04] #1375677
01/26/13 10:19 AM
01/26/13 10:19 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: redraptor] #1375678
01/26/13 09:58 PM
01/26/13 09:58 PM
Elk Grove, Calif.
Elk Grove, Calif.
Like this?
http://www.mopartruckparts.com/images/fuel-tank-sending-unit-75-80-2.jpg
Junkyard for the tank.
That's the "in frame" sending unit!
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: bigblock340power] #1375679
01/26/13 11:57 PM
01/26/13 11:57 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have some in my watch list at $199-250 been there for 4 or 5 months now the guy who has them has a bunch of other NOS truck surplus with that Little Red in his ads for E body prices
Good luck Watch out for the RamCharger in the ads too that makes your Govt surplus part worth more though
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: bigblock340power] #1375680
01/27/13 02:46 PM
01/27/13 02:46 PM
dmnrr04 Offline OP
dmnrr04  Offline OP
Under the frame
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: redraptor] #1375681
01/27/13 02:49 PM
01/27/13 02:49 PM
dmnrr04 Offline OP
dmnrr04  Offline OP
Yes, where and how much are they, I'll buy several
Thanks,
Rick
940-390-9013
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: dmnrr04] #1375682
01/27/13 04:06 PM
01/27/13 04:06 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
http://www.dodgeconnection.com/catalog/item/2862767/4096174.htm
We have plenty for the along the frame ones
David S.
Part Time Owner
Dodge Connection
904-209-9388
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: LilRed7879] #1375683
01/28/13 07:27 PM
01/28/13 07:27 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
In the frame, under the frame, along the frame. What The Frank is everybody talking about? I thought it was a saddle tank.
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: redraptor] #1375684
01/28/13 09:08 PM
01/28/13 09:08 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
It has many names like I do when my wife is mad at me lol
Re: Dodge Truck Fuel Sending Units 1973-1979 [Re: 76dodgeboy] #1375685
01/29/13 06:08 AM
01/29/13 06:08 AM
Elk Grove, Calif.
Elk Grove, Calif.
Yah, but try to ride one !!!
