Re: Thinking bout replacing my DD with a Jeep Cherokee....
[Re: stormer41]
#1375562
01/25/13 06:26 PM
01/25/13 06:26 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
[Re: 76dodgeboy]
#1375565
01/25/13 06:45 PM
01/25/13 06:45 PM
dogdays
[Re: dogdays]
#1375566
01/25/13 10:56 PM
01/25/13 10:56 PM
Posts: 1,156 Cruising!
QuickDodge
Cruising!
The Grand Cherokee was a more upscale, luxury vehicle. In certain years the 4.0 six was available in the Grand Cherokee. Other models had the 5.2 (318 magnum), the 5.9 (360 magnum), the 4.7 engine, and I think some of the newer ones had the 5.7 Hemi as well.
The Grand Cherokee is nicer than the regular Cherokee, but will most likely cost more to own. The regular Cherokee has a better repair record in most if not all model years. (In some model years it's MUCH better!) The Grand Cherokee with the 5.2 & 5.9's have a reputation for being gas hogs.
I own a regular Cherokee that has most of the bells and whistles found on the Grand Cherokee. The well equiped Cherokees aren't real common in this area, but can be found with a little searching. If it's going to be driven primarily on the road, I'd get one with the handling package. The easy way to identify these models is to look for a rear sway bar. Mine is an automatic. It has the transfer case that has full time and part time four wheel drive along with 2 wheel drive. On the winter roads around here, I really like the full time 4x4 option. In some areas that may not be an important consideration.
[Re: QuickDodge]
#1375567
01/26/13 12:40 AM
01/26/13 12:40 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
The main down side to any of the Cherokee's was electrical wiring. They didnt have a great track record.
But thats not to say they are junk. But if you can find one with fewer power options you may save some gremlin chasing in the future.
Also the XJ's were prone to rust, but in the price range you are looking, that shouldn't be as much of an issue.
the 4 cylinder was nearly bullet proof, and they are a very capable line. Numerous aftermarket goodies for them as well.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
