89 FI truck - does engine have mount for fuel pump? #1375503
01/25/13 02:47 PM
01/25/13 02:47 PM
Up a holler, down a crick
booger Offline OP
booger  Offline OP
I'm considering an 89 fuel injected 318 truck. Wondering if things turn to junk on it, will I be able to switch to a carb and mechanical fuel pump setup. I realize the tank would probalby need changed, mostly wondering if I had to, could I mount a normal 318 fuel pump to the block or not? I haven't seen the truck in person yet, so I wanted to ask first.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: 89 FI truck - does engine have mount for fuel pump? [Re: booger] #1375504
01/25/13 04:25 PM
01/25/13 04:25 PM
dogdays Offline
dogdays  Offline
Well, I don't know why you'd want to run a mechanical pump when you already have an electric pump in the tank. You just need a pressure regulator with a return line, and your setup probably already has a return line. TBI system fuel pressures are normally from 13 - 15 psi, can be regulated down to 5 or whatever pretty simply.
R.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: booger] #1375505
01/25/13 04:31 PM
01/25/13 04:31 PM
scratchnfotraction Offline
the t-cover should have a block off plate where the FP would go.
the cam will be a short nose roller cam and no mech fuel pump ecentric.
you can get an adaptor/extintion piece from hughes to go on that cam so a mech fp will work.
or
replace roller cam with a long nose aftermarket cam.
or
you can tap into the wireharness to run the intank fp but will need a pressure regulator up by the carb to cut the pressure down to 5-6 lbs.
when converting to carb you need to look and see if the wireharness under hood has a VR on the firewall... if not when you by-pass the pcm to run carb you will need to wire in a VR to by-pass the pcm alt charge control as well
those 2 things should let it work with out any problems. this will also leave it mostly intact and not have the shadetree whack and hack to the harness.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: scratchnfotraction] #1375506
01/25/13 04:36 PM
01/25/13 04:36 PM
oh! and if you remove the tbi intake and throttle body for a carb you will need to swap out the throttle valve bracke/linkage to the stock carb kickdown linkage.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: scratchnfotraction] #1375507
01/25/13 04:45 PM
01/25/13 04:45 PM
booger Offline OP
booger  Offline OP
Thanks y'all. Sounds like it'd be about as easy to just go 440 if it all fails and I have to start replacing stuff.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: booger] #1375508
01/25/13 06:44 PM
01/25/13 06:44 PM
dogdays Offline
dogdays  Offline
I don't see where everyone is so hung up on mechanical pumps. Most people don't even understand how they operate.
Now if one used a Holley electric pump and the matching Holley regulator that'd appear to be pretty normal. But replace the Holley electric pump, which will pump at around 13 - 15 psi, with an in-tank electrical pump at the same pressure and it gets too complicated to deal with?
Believe me, replacing a fuel injected 318 with a 440 in a 4WD truck is nowhere as easy as wiring up a distributor, plumbing in a carburetor and regulator, hanging on the correct linkage, and possibly adding a voltage regulator.
My '93Suburban has 253K miles on it and the TBI still works. The Delphi/Delco system can't be THAT much better than what's in a Dodge!
R.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: dogdays] #1375509
01/25/13 07:53 PM
01/25/13 07:53 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I didn't see 4wd mentioned. A 440 swap is rather easy If you have everything needed. As stated no need to ditch the fuel system if swapped to carb. plus probably cheaper to replace the electric fuel pump than to by a mechanical pump the snout extension gaskets tank fuel line.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: 76dodgeboy] #1375510
01/25/13 10:42 PM
01/25/13 10:42 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Wht do you want to change from the TBI to carg? What do you expect to gain?
I am truckless..
Re: 89 FI truck - does engine have mount for fuel pump? [Re: 340SHORTY] #1375511
01/25/13 11:23 PM
01/25/13 11:23 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
He said if system "Fails"
Re: 89 FI truck - does engine have mount for fuel pump? [Re: 76dodgeboy] #1375512
01/26/13 12:25 AM
01/26/13 12:25 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Correct me if I am wrong, but don't the LA motors use a bolt on fuel pump eccentric that fits on after the timing gear? So there is no lobe on the camshaft itself.
Its been a LONG time since I was into an LA motor, so my memory could be failing me.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 89 FI truck - does engine have mount for fuel pump? [Re: hp383] #1375513
01/26/13 12:27 AM
01/26/13 12:27 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Yep! its a bolt on piece. Not sure if it would fit directly onto the cam/timing gear but it does bolt on.
Ahh I see what scratch is saying, the cam doesn't have the tabbed end to fit the eccentric.
Found the part at Hughes its a $26 deal
Re: 89 FI truck - does engine have mount for fuel pump? [Re: 76dodgeboy] #1375514
01/26/13 12:35 AM
01/26/13 12:35 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Or we get hit with an EMP!!!
Re: 89 FI truck - does engine have mount for fuel pump? [Re: hp383] #1375515
02/07/13 11:13 AM
02/07/13 11:13 AM
booger Offline OP
booger  Offline OP
Well I had one guy in my ear making it sound as if the pump goes out regularly, and we all know it only fails when the tank's full. So I was thinking screw that the first time is the last time.
I talked to a local guy who has sold cars since back when the trucks were new and all the way back to his grandfather and dad had a small town Dodge dealership. He said that's crazy, they rarely go out.
Still, I'm trying to limit my search to carbureted trucks, because that's what I know and I'm a tinkerer.
Thanks all
Re: 89 FI truck - does engine have mount for fuel pump? [Re: booger] #1375516
02/07/13 11:27 AM
02/07/13 11:27 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
That guys right. The Walbro factory pumps run a long darn time. And the 89 still had replaceable in line filters too.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: buildanother] #1375517
02/10/13 03:10 AM
02/10/13 03:10 AM
dogdays Offline
dogdays  Offline
1989, 1991, 1993 cars that i owned the fuel pumps lasted around 120K miles. Two were MPFI 40 psi, one was TBI, 13-15psi.
I also like Walbro pumps.
If yer worried about it, run the darn thing almost out of gas and change the freakin pump. Most of them come in kits with new tank level sensors and of course inlet filters.
R.
Re: 89 FI truck - does engine have mount for fuel pump? [Re: dogdays] #1375518
02/10/13 09:04 AM
02/10/13 09:04 AM
booger Offline OP
booger  Offline OP
Yeah that's the right way to go with it. Thanks. Still haven't found one local worth paying for though.
