Part help?? 383 w a/c bracket #1375151
01/24/13 08:16 PM
01/24/13 08:16 PM
California
shamefulcuda Offline OP
California
Guys I have a 69 charger w 383 motor and ac. Had the motor rebuilt and trying to reassemble everything. I'm missing the flat bracket that volts to the passenger side front head that holds the long bolt for the alternator. Thick flat piece with a nut welded on back side. I have no idea what it's called so I can't seem to find one. It's 383-400 w ac only. Otherwise w out this piece the alternator bolt has nothing to attach to. Of course seems like everyone has tossed them out. Anyone know where to get this piece or what it's called? I've ebagged and google searched with no luck.
Re: Part help?? 383 w a/c bracket [Re: shamefulcuda] #1375152
01/24/13 08:51 PM
01/24/13 08:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have a complete A/C set-up for a 383 charger..as in EVRYTHING. I'll check tomorrow for you.
Coming soon!!!!
Re: Part help?? 383 w a/c bracket [Re: shamefulcuda] #1375153
01/24/13 08:57 PM
01/24/13 08:57 PM
central,pa
P
ply64post Offline
ply64post  Offline
P
central,pa
Check out this site.
http://www.hoffmanswinnerscircle.com/cat05.htm
"987TAC" - 1969-74 Big Block Engine with Air Conditioning (triangle only!) - $25 Each
Fits all big block water pumps. Has correct locating dimple and 5/16-18 weld nut for heater hose shield #0058. POWDER COATED semi-gloss black.
Use heater hose support "0058"
Re: Part help?? 383 w a/c bracket [Re: ply64post] #1375154
01/24/13 09:02 PM
01/24/13 09:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that is the one that goes out in front , he is looking for the one behind it , I probably have one in my bucket o' parts ...
Re: Part help?? 383 w a/c bracket [Re: JohnRR] #1375155
01/24/13 09:15 PM
01/24/13 09:15 PM
California
California
Exactly! It's not one posted but the one behind. Went through 3 friends bucket o parts w no luck
Re: Part help?? 383 w a/c bracket [Re: shamefulcuda] #1375156
01/24/13 11:15 PM
01/24/13 11:15 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I know I have one laying around if I can find it. PM me and ill look tomorrow.
I found it. It does not have a nut welded to the back of it, though.
Re: Part help?? 383 w a/c bracket [Re: fastmark] #1375157
01/25/13 07:38 PM
01/25/13 07:38 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
You are referring to the piece circled in green correct?
Thats 383 only
If so I have that piece powdercoated in black...LMK if you want it
1MYTGTX
Re: Part help?? 383 w a/c bracket [Re: 1MYTGTX] #1375158
01/25/13 08:00 PM
01/25/13 08:00 PM
California
California
yes that looks like it. Only thing i notice is it doesnt have nut on back side welded like the ones I've had in past. Although obviously I could put my own nut on back side. Yes, I need it if you can ship it out to me usps priority?? Should fit easily in a padded envelope. PM for price and payment info. Thanks!
Re: Part help?? 383 w a/c bracket [Re: shamefulcuda] #1375159
01/26/13 02:13 AM
01/26/13 02:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It probably doesn't have a nut because the piece itself is tapped ?
Re: Part help?? 383 w a/c bracket [Re: JohnRR] #1375160
01/26/13 07:04 PM
01/26/13 07:04 PM
California
California
Good point johnrr. Still looking guy above couldn't find the part. 😒
