BG Speed Demon carb ok for racing? #1374701
01/23/13 07:32 PM
01/23/13 07:32 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Im in need of a race carb and I found a 750 speed demon for sale kinda close to my area but wanted to make sure these were even a reasonable option? My motor is an old school 383 with TRW pistons, I think the cam is a 520 something lift Lunati and stock 906s in an A body with 5.13 gears.
Re: BG Speed Demon carb ok for racing? [Re: Jonnyj00] #1374702
01/23/13 08:10 PM
01/23/13 08:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
With all the bad reputation stories about Demon carbs I would stay away unless it's a deal you can't refuse
Holley 750 DP carbs are pretty easy to find used
Gus
64 Plymouth Savoy
Dana 60
Re: BG Speed Demon carb ok for racing? [Re: fourgearsavoy] #1374703
01/23/13 08:19 PM
01/23/13 08:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have one, I had to replace the main body because the metal is so soft where the squirters go in. other than that it ran fine. I would stick with a holley though
Re: BG Speed Demon carb ok for racing? [Re: Quicktree] #1374704
01/23/13 09:41 PM
01/23/13 09:41 PM
okla.
sam64 Offline
sam64  Offline
okla.
ran my 850 pretty much out of the box for 5 years,last year i put a wide band o2 sensor on before i switched to e-85 and its ritght on.foot brake car in the low 11's.i'm going to use it on my street beater.
Re: BG Speed Demon carb ok for racing? [Re: Jonnyj00] #1374705
01/23/13 09:50 PM
01/23/13 09:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a reason he is selling it.... most of the
times it was because BG stuff was bad... usually a
quality control issue... I dont buy BG stuff due to that
Re: BG Speed Demon carb ok for racing? [Re: Jonnyj00] #1374706
01/24/13 01:25 PM
01/24/13 01:25 PM
organ
maximum entropy Offline
organ
i have a mighty demon on mine. it's a good carb, once you work out the kinks (it only took a few years). my pump squirter holes stripped out, and i found a supplier in florida who had the appropriate inserts (the only supplier in the country, far as i know). like all bg carbs, it was FULL of metal. i've seen some with cross threaded jets, throttle blades installed upside down, it seems their problems are usually assembly related. i've done a bunch of them, from speed demons, all the way up to race demon rs. they always have metal in them, and some kind of assembly error.
Re: BG Speed Demon carb ok for racing? [Re: maximum entropy] #1374707
01/24/13 01:36 PM
01/24/13 01:36 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Sounds like I'll be passing on that one. Thanks guys.
I have a 750 3310 vacuum secondary holley that they sell a conversion kit for at speedway for like 130 is this a reasonable option? I'm just a broke college student or I would just go by a new carb...
Re: BG Speed Demon carb ok for racing? [Re: Jonnyj00] #1374708
01/24/13 01:51 PM
01/24/13 01:51 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have heard all of the horror stories also about BG. I have a 1090 & a 1290 King Demons & have never had any problems with either one. Now that Holley owns BG most everything is available for them again.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: BG Speed Demon carb ok for racing? [Re: Jonnyj00] #1374709
01/24/13 02:08 PM
01/24/13 02:08 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Conversion kit for a rear metering block? If so, you can piece that together for much less than 130. Probably 30-40 bucks.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: BG Speed Demon carb ok for racing? [Re: Von] #1374710
01/24/13 03:45 PM
01/24/13 03:45 PM
dogdays Offline
dogdays  Offline
The R-3310 750 Holley will work just fine for you. It should be a dual inlet carb, so you might have to change your fuel line on the inlet side when you add a secondary metering block. The kit shouldn't cost more than $50.00 and it allows you to change jets on the secondaries. That's all it does.
There is also an aftermarket metering plate that uses regular Holley jets, doing the same thing maybe for less.
You don't need to change float bowls for either choice.
If you're REALLY bucks-down you could drill and tap holes into the metering plate and use Holley jets.
1/4-32 is the thread size.
Spend money on springs for the vacuum secondaries, too, for tuning.
R.
