Changing SB to a BB #1374518
01/23/13 04:19 AM
01/23/13 04:19 AM
New Zealand
dart6 Offline OP
dart6  Offline OP
New Zealand
Hi My 70 sport sat came from the factory with a SB and I want to run a BB. Is the K frame ok, do i need special engine mounts or just use standard BB mounts
Thx for looking
Re: Changing SB to a BB [Re: dart6] #1374519
01/23/13 04:28 AM
01/23/13 04:28 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Same K different engine mount brackets & BB trans... The engine mount brackets can be found in any Big Block 66-72 C body, B body or E body... Adding a skid plate to the K member to protect the oil pan is a good idea...
Re: Changing SB to a BB [Re: 1_WILD_RT] #1374520
01/23/13 05:28 AM
01/23/13 05:28 AM
New Zealand
dart6 Offline OP
dart6  Offline OP
New Zealand
Does the BB trans use the same cross member
Re: Changing SB to a BB [Re: dart6] #1374521
01/23/13 05:51 AM
01/23/13 05:51 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Same X member, same trans mount.. Same driveline if you have a 727 trans, if not you will need to shorten the shaft by 4" and get a 727 yoke for it.
I am truckless..
