Re: Ring & Pinion WOW! [Re: 65signet] #1374377
01/23/13 11:26 AM
01/23/13 11:26 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
No vibration very smooth going down the track
If the u-joint was hitting something I don't think the OP would've posted this.
Re: Ring & Pinion WOW! [Re: 74yellowduster] #1374378
01/23/13 12:21 PM
01/23/13 12:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
what if the pinion nut was not torqued to spec? could that cause this?
This is my guess
Re: Ring & Pinion WOW! [Re: FastmOp] #1374379
01/23/13 12:45 PM
01/23/13 12:45 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have seen this quite a few times and have done it once myself.Usually it's overtorque that caused the problem.I assumed my airwrench would only torque to 150# wrong.I was left holding the yoke in my hand.Many assume the torque setting for a pinion nut is 240+# or as tight as you can get it with a 2 foot cheater pipe.There are varied setting depending on the pinion stem diameter and if it's straight or tapered.These specs can range from 125#ft to 250#ft.Always check with the manufacture for the correct setting.My thoughts are use a new lock nut,locktight and tighten as needed,you can even center punch the nut in several places to insure it doesn't back off.
Re: Ring & Pinion WOW! [Re: viperblue72] #1374380
01/23/13 03:38 PM
01/23/13 03:38 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
All 4 u joint bolts have been hitting something? ,The issue maybe the axle wrap up and putting drive shaft in a bind would be my best guess
That could be from when it hit the ground spinning at 100+ mph?
Yes close to 115, the driveshaft broke into 3 pieces and 2 pieces went for a ride.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Ring & Pinion WOW! [Re: B G Racing] #1374381
01/23/13 03:41 PM
01/23/13 03:41 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
Pinion nut was tighten to allow for the correct preload on the pinion with new bearings it was set to 20 inch pounds of rotation drag..
Re: Ring & Pinion WOW! [Re: 65signet] #1374382
01/23/13 05:42 PM
01/23/13 05:42 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
What case was this ? 741 , 742 or 489 ? If a 489 did you use a solid spacer or the crush sleeve ?
Did you have a pinion snubber ?
Re: Ring & Pinion WOW! [Re: JohnRR] #1374383
01/23/13 06:19 PM
01/23/13 06:19 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
489 case, solid spacer, and no snubber SS springs Just got off the phone with Richmond and because i got the gears from a friend and the receipt is gone, they will not help me...
Re: Ring & Pinion WOW! [Re: 65signet] #1374384
01/23/13 07:07 PM
01/23/13 07:07 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Did you check/correct the pinion angle when you put those springs on ? Did the yoke hit the floor ?
Re: Ring & Pinion WOW! [Re: 65signet] #1374385
01/24/13 09:07 AM
01/24/13 09:07 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The pinion nut does not set preload.The crush washer if used or if its a straight pinion shims are used to set preload.
Re: Ring & Pinion WOW! [Re: B G Racing] #1374386
01/24/13 03:01 PM
01/24/13 03:01 PM
El Dorado Ca
65signet Offline OP
65signet  Offline OP
El Dorado Ca
My correction on the set up I used the spacer with shims to set preload
Re: Ring & Pinion WOW! [Re: 65signet] #1374387
01/24/13 03:14 PM
01/24/13 03:14 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
