Re: budget turbo Belvedere still alive and well
[Re: RockChip]
#1373370
01/22/13 03:25 PM
01/22/13 03:25 PM
Posts: 281 Michigan
DRAG-ULA
I dig it!!!!! Glad to know the lower end will take that kind of abuse. I'm waiting for my 383 to kick a rod out or break a piston, and I'm only at 12 lbs. Maybe it'll never happen.
1970 Imperial, Low & slow daily driver 1973 Chrysler T&C 1948 Dodge B1 pickup - perpetual project
[Re: Bad340fish]
#1373376
01/22/13 09:17 PM
01/22/13 09:17 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
are those custom headers? They look like shorty's. I'd like to do a turbo set-up like that one of these days. Does all that clear the factory k-frame. Looks sort of like this SB set-up.
I would love to see a pic of the other side of that engine, looks like an "easy" fit in an abody.
sorry found it online. I'm guessing they are shorty headers looks like straight pipe down and under the k-frame over to pass side.
[Re: RockChip]
#1373377
01/22/13 11:03 PM
01/22/13 11:03 PM
Posts: 168 Washington State, USA
Winchester 73
Turbo is a Ebay GT45 y2004k, Ebay 53mm BOV and 60mm waste gate.
Its like a 69mm 105AR exhaust, I have 4-5 years on it now with no problems what so ever.... And we are not nice to it at all!!!
Engine is BONE stock 1968 383 never been apart except for. 280/480 comp juice cam, used one I had laying around double roller chain chrome timing cover lol High volume oil pump And a Torker 383 intake with new valley pan cause the old one was rusted out.
Carb i did myself, it runs on E85
3500 10" stall, colum shift.... I just leave it in drive!!!
3.91 gear witch I will be swapping for 3.23 soon
29x10 Slicks
High 10s @ around 120 so far but fuel system cant keep up so no full power passes yet.
should run low 10s to high 9s @ 130s once fuel seystem keeps up
BTW!!! car is FUN to drive !!!! layer on the wood and let the Turbo do the talkin LOL !!!!!
thank you for building this!you must have done this in a secret location away from the moparts gestapo.at the minemum for boost you need pistons from some sort of metal that came from a meteor,aftermarket block,the newest of heads that JUST got developed and then sent to some wichdoctor for porting ect,ect and if all this fails they would tell you to turbo a stock LS1
[Re: gtsdude]
#1373378
01/22/13 11:33 PM
01/22/13 11:33 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
would spend a little more money and get a master power or a borg warner. Those turbos are cheap for a reason
I hear what your saying about those chinese turbos, but check out theturboforums.com. They have a thread about the gt45 that a bunch of guys are using and seems to hold up and make power.
I agree 100%. If others are having luck i guess its worth a try. I got lucky and picked up a new s480 from a buddy for peanuts. glad to see that there will be other turbo mopars out to play with.
[Re: RockChip]
#1373381
01/23/13 02:07 AM
01/23/13 02:07 AM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
And yes !!!!! dizuster don't be afraid to turn the wick up !!!! LOL
I never really like driving the car untill 15psi
Im gonna blame you cause now the gears are turning in my brain for a turbo deal on my cast piston 440...Boost just looks so fun. Your car truly is badass.
[Re: Winchester 73]
#1373383
01/23/13 02:50 AM
01/23/13 02:50 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Exactly! The reason turbo Mopars arent more predominant is simply because people dont build them.
Mopar to the bone!!!
[Re: RockChip]
#1373385
01/23/13 03:36 AM
01/23/13 03:36 AM
Winchester 73
Well hopefully this will change things
And if anyone needs info on the build I will try my best to help them out !!!!
i have a 73 dart sport with a fresh rebuilt cast piston 383 with the very same cam 8 3/4 with 3.23 stock 727.lots of carbs to play with -e85 is sold about twenty minutes from my home.im thinking about doing this with reversed stock manifolds.
how much to setup a carb for me?
