I've had alot of guys call me and ask if the AIRWOLF 220 head will work on a 360. So we put a 360 together with a bunch of old parts that Dulcich had laying around. The goal was to build a budget style 360 that could make some killer power. Take a look at the tq @ 2500
360 Test engine specs
4.040 bore x 3.58 stroke
Stock Crank Turned 10/10
Scatt I beam Rods 7/16 bolts
Probe Flat top pistons 1/16 1/16 3/16 ring package
10.35 to 1 with 67cc chamber
Engle KV3 Hyd flat tappet 241/241 @ .050 .367 Lobe 110 LSA
AIRWOLF 220 Heads
Beehive Spings Set up for Hyd flat tappet 145lbs on the seat 395 lbs open
1.6 rockers .588 lift intake and exhaust
Dr J's Ported Weiand X-Celerator
Holley Ultra Hp 950
TTI headers 1 5/8 -1 3/4 chassis headers
30wt dello 400 oil
Milodon oil and windage try
http://youtu.be/OeX3LWkJKWg
