Re: AIRWOLF 220 Sbm heads tested on 360
[Re: J_BODY]
#1373192
09/04/13 11:30 PM
09/04/13 11:30 PM
Posts: 33 Louisiana
Bignick
Louisiana
What is Dr J's facebook page called? Can't find it.
70 Duster 422"eddy head smallblock, PTC built 904, PTC 8" conveter, Dana 60 4.56 gear
[Re: rolling 340]
#1373195
09/05/13 10:05 PM
09/05/13 10:05 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The Wife called and said a Dr. J's box arrived on Tuesday, but I'm already in OK, getting ready for Drag Week. Thanks for the effort, and kind words J-body, even if I'm not in "the Club"!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1373196
09/05/13 10:40 PM
09/05/13 10:40 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Billy, Enjoy Drag Week. We'll need to get together at the track one of these days. It's been a while . matt
[img] [/img]
[Re: clonestocker]
#1373197
09/05/13 10:46 PM
09/05/13 10:46 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
What I am itching to know is if these heads will support an honest 650 ponies with a good non exotic roller cam shortblock under them 400+ inch 4 inch motor... If so If not.....
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Triple Threat]
#1373199
09/06/13 08:23 PM
09/06/13 08:23 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My offer still stands for a FREE flow test. Then we will know how they stack up against Edelbrocks or Indy's
[Re: Triple Threat]
#1373200
09/06/13 09:43 PM
09/06/13 09:43 PM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
If not.....
I wonder this as well. Hopefully some of these guys buying them up will share numbers with us when the motors are together. My current 59* motor makes about 625, but its bigger and fancier than most.
Dustin What is you car running now, 1/8 & 1/4?
[Re: Bryce Mulvey]
#2340496
07/20/17 07:12 PM
07/20/17 07:12 PM
Posts: 89 Australia
MisterBee
Australia
Hi All,
Its been a while, and probably a moot point now because so much time has passed. However, I finally got to take my AIRWOLF 220 heads to a reputable head/ engine shop in the last couple of weeks (yes 4 years later...I know)
The shop were initially skeptical of the advertised numbers but were impressed with the results and the quality of the heads generally...here are the results;
Lift .100 .200 .300 .400 .500 .600 .700 .800 .900 Cyl 1 Int Corr. CFM 61.7 137.9 203.2 256.0 290.8 297.8 304.4 309.1 312.6 Cyl 1 Exh Corr. CFM 58.4 110.0 147.3 175.5 194.4 209.6 218.8 221.8 222.4
I'll try and show you the full sheet once I work out how to load it (PDF).
[Re: Bryce Mulvey]
#2340497
07/20/17 07:16 PM
07/20/17 07:16 PM
B3422W5
Portage,michigan
Very impressive at 1/2 inch
