Page 1 of 7 1 2 3 4 5 6 7
AIRWOLF 220 Sbm heads tested on 360 #1373109
01/20/13 11:28 PM
01/20/13 11:28 PM
anaheim Ca
Bryce Mulvey Offline OP
anaheim Ca
I've had alot of guys call me and ask if the AIRWOLF 220 head will work on a 360. So we put a 360 together with a bunch of old parts that Dulcich had laying around. The goal was to build a budget style 360 that could make some killer power. Take a look at the tq @ 2500
360 Test engine specs
4.040 bore x 3.58 stroke
Stock Crank Turned 10/10
Scatt I beam Rods 7/16 bolts
Probe Flat top pistons 1/16 1/16 3/16 ring package
10.35 to 1 with 67cc chamber
Engle KV3 Hyd flat tappet 241/241 @ .050 .367 Lobe 110 LSA
AIRWOLF 220 Heads
Beehive Spings Set up for Hyd flat tappet 145lbs on the seat 395 lbs open
1.6 rockers .588 lift intake and exhaust
Dr J's Ported Weiand X-Celerator
Holley Ultra Hp 950
TTI headers 1 5/8 -1 3/4 chassis headers
30wt dello 400 oil
Milodon oil and windage try
http://youtu.be/OeX3LWkJKWg
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Bryce Mulvey] #1373110
01/20/13 11:33 PM
01/20/13 11:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice numbers for sure!
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Bryce Mulvey] #1373111
01/20/13 11:33 PM
01/20/13 11:33 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That's pretty cool!
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: J_BODY] #1373112
01/21/13 12:24 AM
01/21/13 12:24 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Nice build and great results!
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: 69Cuda340S] #1373113
01/21/13 01:00 AM
01/21/13 01:00 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Very nice numbers and for not a ton of money either.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: tubtar] #1373114
01/21/13 03:51 AM
01/21/13 03:51 AM
sweden
sshemi Offline
sshemi  Offline
sweden
What rockers are those?
And how much for those heads?
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: tubtar] #1373115
01/21/13 03:53 AM
01/21/13 03:53 AM
anaheim Ca
anaheim Ca
Bryce Mulvey Dr J's Performance The Home of AIRWOLF Cylinder Heads
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Bryce Mulvey] #1373116
01/21/13 04:13 AM
01/21/13 04:13 AM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
Can you post the flow #s for these heads you used on this build? Id like to see how they compare to Brian's prepped RHS heads.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: 72swgnr] #1373117
01/21/13 04:31 AM
01/21/13 04:31 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://board.moparts.org/ubbthreads/show...e=1#Post7398767
alot more info..
Tony
70 AARCuda Vitamin C
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: 70AARcuda] #1373118
01/21/13 04:34 AM
01/21/13 04:34 AM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
alot more info..
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: 72swgnr] #1373119
01/21/13 09:00 AM
01/21/13 09:00 AM
The Great White North
RAMM Offline
RAMM  Offline
Bryce nice results. Can you fix your average at the bottom of the columns-It looks like it is using the median method and not the sum divided by total points method. Do you think the cam is what limited peak power at 6200 rpm? How were you circulating water without turning the pump in the video? Oh and you should sell me that X-celerator, I could use it for my own cratekiller program. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: sshemi] #1373120
01/21/13 10:36 AM
01/21/13 10:36 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Those are Erson roller rockers
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: RAMM] #1373121
01/21/13 10:38 AM
01/21/13 10:38 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I can't wait for nice weather an the tracks to open back up to test the Airwolfs on the 414.
Probably need to jet it up over the old SDSS Stage 2's, really looking forward to the spring. They are definately a super nice set of SB heads, I'd like to see bryce work up a set with an offset rocker and the pushrod pinch either eliminated or tubed, if they flow this good with a standard rocker they could be even that much more awesome! I'll offer these up as the test mules since they did so great the last (633 horse 408) time
For anybody who has any reservations about the overseas quality of the castings.....DON'T. the quality is actually as good or Better than any domestic castings I've seen and everything bolts up and sealed up perfectly.
WIZE
In Car:
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Streetwize] #1373122
01/21/13 11:04 AM
01/21/13 11:04 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Hughes has a rocker thats 0.2" offset.
That would be intressting
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: sshemi] #1373123
01/21/13 11:42 AM
01/21/13 11:42 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Also, just like shown on the 408 motor graph, the torque is very broad and maintains at least 85-90% of peak over a very broad RPM range; Ex: look how long you have at least 420 lb/ft from on a 495-ish peak...over a 3000+ rpm range. IMO that is the sign of a well executed and HP/Tq efficient combo, broad torque that results in a near linear hp curve (which is the rate of HP gain per RPM increase). Broad torque gives you a combo that will work well on the street as well as at the track, don't overcam, keep the Peak torque RPM at a reasonable RPm level for block preservation and let good flowing heads and induction do the HP work above that RPM point to keep as much of the torque for as long as you can.
WIZE
In Car:
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: RAMM] #1373124
01/21/13 01:16 PM
01/21/13 01:16 PM
anaheim Ca
anaheim Ca
J rob
the intake is the limiting factor on the peak power it a has a smaller CSA in the runner than the heads I'm not a big fan of it but seams to work ok. A old strip domintaor would be the best choice
We used a stand along water pump for the dyno testing and the blades were cut out of the water pump.
I'll look in to averages. The dyno is set up in stock DTS forum.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Bryce Mulvey] #1373125
01/21/13 01:26 PM
01/21/13 01:26 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Bryce you got pm
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: sshemi] #1373126
01/21/13 03:15 PM
01/21/13 03:15 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Bryce you got pm
And again
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: sshemi] #1373127
01/21/13 09:08 PM
01/21/13 09:08 PM
anaheim Ca
anaheim Ca
took the engine off the dyno and man this thing was running clean!!
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Bryce Mulvey] #1373128
01/21/13 09:28 PM
01/21/13 09:28 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
your AFR's reflect the way that valve looks - it was leaner then I like to run it for the most power if they were accurate.
